Date/Time: Thu, 26 Nov 2026 03:31:28 +0000
[User Discussion] - Symbols appearing on a Spreadsheet in both columns A and B
View Count: 367
[2026-03-13 18:44:44]
UserName_AB2 - Posts: 1
I have read much of the necessary documentation. I've searched the Support sections of the website, but still can't find a fix to the following issue:
When new Symbols are added to Column (A) they also appear immediately in Column (B). This appears to be a system error. It is fully redundant and, as far as I know, unnecessary. I can't deduce a 'performance issue' from this. But when I see something like this in software, it tells me something is wrong.
I do not see anything similar on the following image posted in the documentation: https://www.sierrachart.com/images/GQ_img1.png
I'm competent in Excel. I've done lots of Excel development with live data APIs and VBA. I've never seen this problem in a desktop or browser window spreadsheet or database before. I have attempted to attach the spreadsheet file (20260209_SnP500.scss) but the current form -- https://www.sierrachart.com/Attach.php? would not load it.
Please advise, I need working spreadsheets to function with both live data and static Fields for my trade systems.
...I'm having other Spreadsheet problems too but will address them separately as requested.
Private File
[2026-03-13 21:23:20]
Is this from one of the spreadsheet studies, or is this a "standard" spreadsheet (opened by selecting "File >> New Spreadsheet"), or is this a Quote Spreadsheet?
It sounds like you opened the spreadsheet as a Quote Spreadsheet as what you state about the symbol repeating in Column B, is how the Quote Spreadsheet works. Refer to the following for the Quote Spreadsheet:
Getting Quotes: Quotes on Spreadsheets
It sounds like you are probably wanting to use one of the spreadsheet studies. Refer to the following:
Spreadsheet Systems, Alerts and Automated Trading
Keep in mind that with the spreadsheet studies, the formula columns are setup to copy the formula entered in row 3 down the full row. It may seem a bit odd at first, but it makes perfect sense when you understand how the spreadsheets are setup, and that each row represents one bar of data.
