Date/Time: Thu, 26 Nov 2026 03:31:20 +0000
How to change denali data feed server location
View Count: 439
[2026-03-12 15:55:54]
pinetrades - Posts: 19
I currently use the denali data feed for CME and CBOT futures. I found the documentation that outlined all of the servers you have, and I have two questions.
1) How can I verify which specific server I am connected to for real time data? I went through the message log and I could only find servers related to historical data. I could have missed it though.
2) How can I set a specific server for real time data? For example: Lets say the server I am currently connected to (which Sierra Charts selects automatically) is not ideal due to poor routing issues, and I want to use a different server in a different location. How do I set that? I went through where the documentation mentions setting a server, but I could not find the specific field within the options in SC.
Thanks!
[2026-03-12 20:18:47]
To find out what server you are currently connected to, start at the end of your Message Log and search backwards for an entry that looks like the following:
2026-03-12 13:51:57.746 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 443
That is the server you are connected to at that time. Each time you disconnect and reconnect to the data feed, you will be connected to a different server.
To specify a specfic server for the CME Group data, refer to the following:
Sierra Chart Server Settings: CME Exchange Data Feed Server Address and Port Override (Global Settings >> Sierra Chart Server Settings >> General >> Special)
