Date/Time: Thu, 26 Nov 2026 03:41:32 +0000
Rollover
View Count: 489
| [2026-03-12 15:29:52] |
| DobkeTR - Posts: 2 |
Hello, My sierra chart account says that symbol needs Rollover. I trade NQ only. when I choose from NQH26_FUT_CME to NQM26_FUT_CME, my charts is messed up. I added screenshot |
| [2026-03-12 15:36:46] |
| User135243 - Posts: 337 |
I guess you're using an old version, where there was a problem with roll-over, so you should update SC (volume will roll to June-contracts on Mon or Tue next week)
| [2026-03-12 15:44:06] |
Why do you state that the NQM26_FUT_CME chart is messed up? It looks correct for what it is at this point in time. In particular, it does not have a lot of trading yet. As stated by User135243, there were some changes to how Sierra Chart handles the notification for Volume rollover in recent releases. It was not wrong previously, but we improved it so that it is more robust now and will not give notifications due to a momentary eclipse in the volume. To update to the latest release follow these instructions: Software Download: Fast Update It is up to you as to whether you want to stay with the new contract or go back to the previous one. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-16 15:46:20] |
Hello, Maybe you know how to fix those gaps after rollover? or how to add previous contract data to the new one? it messes with my volume profile. Thank you |
| [2026-03-16 16:59:39] |
Those gaps are real. That is due to the low trading of that symbol at that time. There is nothing to fix in terms of the data. If you want to view the previous contract prior to the current rollover date, then refer to the following: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
