Date/Time: Fri, 18 Jul 2025 22:59:28 +0000
ACSIL: a SCFloatArray larger than sc.ArraySize
View Count: 1169
[2014-10-25 12:58:35] |
Zosimus - Posts: 345 |
Is it possible to create a SCFloatArray larger than sc.ArraySize ?
[2014-10-25 20:19:44] |
No. You just have to allocate your own array. Refer to this section here: http://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#DynamicMemoryAllocations Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
