Date/Time: Thu, 26 Nov 2026 03:31:25 +0000
Triggered Trail Stop - Move to Break Even for Stop - Halt Stop at Entry price
View Count: 394
[2026-03-10 18:43:32]
User469662 - Posts: 2
I am currently using a Triggered Trail Stop coupled with the Move to Break Even for Stop using the following settings in Ticks:
- Stop Offset: 100
- Trail Offset: 170
- Trigger Offset: 70
- Type: Offset in Ticks Triggered
- BE Level Offset: 0
- Trigger Offset: 170
- Step 1
Please let me know what modifications I need to make in order for the Stop to halt at the Entry Price as opposed to continuing to trail price. Notes: I would like the Stop to naturally trail to the Entry Price as opposed to jumping to the Entry Price when the Trigger is hit. I do not have a Target only a Stop. Group is: OCO Group 1.
Date Time Of Last Edit: 2026-03-10 19:12:03
[2026-03-10 20:39:10]
There is not a built-in option to have a Trailing Stop that stops at Breakeven.
To do this, you would need to use a combination of the "Spreadsheet System for Trading" and the "Trade Management by Study" studies.
The "Spreadsheet System for Trading" would be used to establish the level at which you want the Stop to move to. You need to use this study as it gives you the Position Average Price (breakeven price) in cell J9. So you can use that to setup column O to give you the line you want. It's easiest to not use cells K, L, M, or N for anything, as those are special to entering and exiting orders with that study.
The general idea would be to setup a formula that moves the stop based on the last price and to not move any further when the price gets to breakeven. The hardest part of this is setting up the formula to not allow for the Stop to move down. You will have to get a bit creative with this.
Then the "Trade Management by Study" will actually move the Stop to that line.
Refer to the following:
Spreadsheet Systems, Alerts and Automated Trading
Attached Orders: Study Controlled Targets and Stops
