Date/Time: Thu, 26 Nov 2026 03:31:25 +0000
Large volume trade indicator
View Count: 365
[2026-03-10 15:41:09]
Baran Akbas - Posts: 3
Hi guys,
I'm unable to get the Large volume trade indicator to work. I use the denali data feed. When I apply the indicator, nothing happens.
thank you
[2026-03-10 15:42:17]
The Large Volume Trade Indicator will only work properly when you have your data set to be stored at every tick. Check the following setting and make sure it is set to "1 tick":
Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings)
If it is already set to 1 tick, then we would need to know 1 symbol for which you are having a problem.
