Date/Time: Thu, 26 Nov 2026 03:31:27 +0000
Can I use separate connections for data and orders and if yes, how?
View Count: 415
| [2026-03-10 14:24:24] |
| RowJay12 - Posts: 3 |
Hi, I'd like to use the Denali feed for market data (which I'm already doing), and a separate external Rithmic feed for placing orders / trading. Is that possible, and if it is, how do I configure that?
| [2026-03-10 15:09:52] |
You can use our Denali data feed for your data and trade with Rithmic - which is what we think you are asking. Refer to the following: Denali Exchange Data Feed: Integration with Trading Services To connect to Rithmic, follow these instructions: Rithmic Trading Platform Service: Setup Instructions If you are really wanting to do something with data from both Denali and Rithmic, then this is not something you can do, and we are not really even understanding the question in this case. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
