Date/Time: Thu, 26 Nov 2026 03:31:28 +0000
Milisecond data
View Count: 370
| [2026-03-06 21:25:19] |
| User587417 - Posts: 9 |
Hi, How to check speed data Denali (from my computer in Poland to Rithmic) in milisecond?. I think about VPS, but I am not sure that is good solution?. Could you tell me something about this?
| [2026-03-06 22:02:54] |
To see how much latency you have with your data, make sure you have the "Data Delay" option displayed in your "Chart Header". It will show in there with a prefix of "DD:". Refer to the following for how to add this if it is not there, or to move it where it is visible: Working With Charts: Region Data Line / Chart Header As long as your computer clock is set to match the clock of the exchange (which is the national standard time) then this will give you the latency for where you are located. But remember, your computer clock must be synchronized. We offer a way to do this with Sierra Chart. Refer to the following: Network Time Protocol Client For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
