Date/Time: Tue, 03 Nov 2026 17:44:15 +0000
testing Sierra but need live CL (WTI future) data
View Count: 480
| [2026-03-04 13:53:20] |
| User943793 - Posts: 2 |
Hi team, I just entered the trial but I only trade oil. For me to really test the system I need to get connected to live data feed on CL. what would be the best and cheapest way to do this?
| [2026-03-04 15:17:58] |
| John - SC Support - Posts: 48408 |
You would have to change to one of the paid packages. If you are fine with testing with our Delayed Streaming Data, then you can get one of the "Base" packages. The exact one you need will depend on your charting needs. Refer to the information for the packages at the following link: Description of Service Packages and Pricing: Packages To change to a paid package, follow these instructions: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-04 16:00:52] |
i need the numbersbar (footprint chart). happy to try with delayed data . Is this the package I should get then: Base Sierra Chart with Advanced Features (Service Package 5)? Also what would the datafeed cost when I decide to go live? |
| [2026-03-04 16:40:04] |
In order to have access to the Numbers Bars study with the delayed streaming data, you have the correct package (Base Advanced). The first thing to consider for the cost, is that you would have to be on one of the "Integrated" packages. The equivalent package in the Integrated options is the "Integrated Advanced" which costs $46.00 per month ($10.00 more than the Base Advanced). Then the cost of the exchange depends on what you need for the data. You will find the exchange fees at the following link: Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
