Date/Time: Thu, 26 Nov 2026 03:19:34 +0000
Delay on data from Eurex?
View Count: 374
| [2026-03-02 08:49:07] |
| User266447 - Posts: 281 |
Do I have a delay on receiving data from EUREX?
| [2026-03-02 16:08:21] |
You are setup to get the real-time data for EUREX from our Denali Exchange Data Feed. Are you seeing a particular issue? If so, what is occurring? If you have the "Data Delay" showing in your Chart Header (it will be preceded with "DD:") then what is that value showing? If you do not have the "Data Delay" in your chart header, then please add it and let us know what it states. Refer to the following: Working With Charts: Region Data Line / Chart Header For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
