Date/Time: Thu, 26 Nov 2026 03:19:32 +0000
DTC protocol Demo
View Count: 521
| [2026-03-02 06:45:47] |
| 284630 - Posts: 15 |
Hi, Sierra team: I'm currently to developing a trading hub tools, which is winx64 application. The purpose is for connnecting CQG、 ProjectX etc, trading API to copying my sierra orders. When I looking through DTC protocol instruction, the page says "The DTC Working Group will provide simple C++ projects which use the DTC Protocol. These will serve as examples." But I couldn't find any links or available demo on the github or something else. I need some basic DTC demo for better understanding how it works. |
| [2026-03-03 20:48:43] |
| Sierra_Chart Engineering - Posts: 25489 |
We never did create any simple sample projects. The protocol is documented here: Table of Contents | (External Interfaces) DTC Protocol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
