Date/Time: Tue, 07 May 2024 09:54:07 +0000
Dow Futures chart
View Count: 2065
[2013-05-14 14:08:07] |
User54027 - Posts: 128 |
Hi, I currently am using your US30 US Dow Jones Index Chart. Where can I see the dow futures chart if I need to see the difference in price value between the 2 charts. Many Thanks |
[2013-05-14 22:17:09] |
For this you need to use the Sierra Chart Historical Data Service: http://www.sierrachart.com/index.php?l=doc/SierraChartHistoricalData.html You may want to install a 2nd copy of Sierra Chart to use this service: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
