Date/Time: Thu, 26 Nov 2026 03:19:23 +0000
delimitation interval on graph study
View Count: 434
[2026-02-27 15:31:14]
User166249 - Posts: 28
hi
i want to set start and end of period on the graph and automaticly save it in a csv
which study to i have to use?
it is because i have to extract patern with ML but i have to feed him with reference period ive set limit by myself
thank
[2026-02-27 16:52:53]
Do you need help with setting the Start and End period?
We assume you are wanting to export the main price graph to a CSV file. If this is something you just need once in awhile, then you can use the "Edit >> Export Bar Data to Text File" option. Refer to the following:
Edit Menu: Edit >> Export Bar Data to Text File
If you want to have the data constantly written out, then refer to the following study:
Write Bar Data to File
[2026-02-28 23:28:13]
hi
i mean to define interval on the curve witch corresponding to a special regime A for exemple.
For exemple to delimitate a preriode A : i click a 14h43 min (the stat of the period A) and then at 15h59 for exemple (the end of the period) then the study automaticly feed on a csv a colonne A with start and end time.
then i feed ma machine learning tool with that.
thank
[2026-03-01 02:18:17]
Sierra_Chart Engineering - Posts: 25489
You are going to have to create your own custom study to do this. Refer to:
Advanced Custom Study Interface and Language (ACSIL)
[2026-03-01 14:59:01]
can you recommend me a programmer’s company?
[2026-03-02 14:51:28]
A list of potential programmers can be found here:
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
