Date/Time: Thu, 26 Nov 2026 03:19:24 +0000
Unable to combine current traded bid and ask volume bars
View Count: 671
| [2026-02-26 23:09:58] |
| dTrades1026 - Posts: 2 |
I need to help combining the current traded bid and ask volume bars. I have the tick setting on 1 and in replay mode it combines, but in live inly the pulling and stacking column combines. I've tried setting the ticks to .25 and the combine increments to 4 and the multiplier for intraday chart to 4. However this also doesn't work.
Attachment Deleted. |
| [2026-02-27 15:29:22] |
Set the Tick Size back to the default value for that symbol. Then set the "Chart >> Chart Settings >> Market Depth >> Market Depth Combine Increment in Ticks" to what you want it to be. Then set "Chart >> Chart Settings >> Market Depth >> Apply Combine Increment in Ticks to Other Market Data Columns" to "Yes". Refer to the following: Chart Settings: Apply Combine Increment in Ticks to Other Market Data Columns (Chart >> Chart Settings >> Market Depth menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-27 20:31:12] |
I've set the ticks to .25 and the market depth combine increments to 4 and have turned on apply combine increments, but it doesn't seem to have worked.
Date Time Of Last Edit: 2026-02-27 20:39:24
| [2026-02-27 20:43:51] |
Why do you state that it is not working? We see that the data is aggregated at each whole number price.
