Date/Time: Thu, 26 Nov 2026 03:19:26 +0000
Teton Routing Historical Fill
View Count: 414
[2026-02-26 15:45:08]
User872629 - Posts: 3
As I entered a position (with OCO orders), I noticed that my NPL suddenly went negative. When I looked at the chart and activity monitor I noticed another order appeared marked as Teton Routing Historical fill. (see attached screenshot)
Please clarify what happened and how it affects the balance.
Private File
[2026-02-26 17:15:58]
Sierra_Chart Engineering - Posts: 25489
First, you are running an old version of Sierra Chart. You must update. This is critical. Instructions:
Once that is done, delete that particular trade activity entry with the incorrect Date-Time. Instructions:
Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log) (Delete Trade Activity Entry)
[2026-02-26 17:22:15]
Ok, I upgraded the version and restarted.
1. NPL is showing 0 after restart - how to sync it?
2. That wrong historical fill - does it have any impact on the actual balance? Please clarify what happened and the impact.
3. I will delete the wrong record once I understand that above two points.
[2026-02-26 17:32:28]
Regarding this:
It depends upon various settings. They are all explained here:
Help With Daily Profit/Loss Value
Check these:
Chart Settings: Filter Initial Fills Which Are Part of Existing Position (Chart >> Chart Settings >> Trading menu)
Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List
Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu)
Chart Settings: Load Order Fills for Current Day Only (Chart >> Chart Settings >> Trading menu)
Chart Settings: Start Time for Trades List (Chart >> Chart Settings >> Trading menu)
No:
There was a missing fill that was downloaded but the earlier version you are running does not handle, the particular timestamp format.
Date Time Of Last Edit: 2026-02-26 17:33:13
