Date/Time: Thu, 26 Nov 2026 03:19:25 +0000
Receiving the data stops when Open Market Depth Window turns on.
View Count: 434
[2026-02-25 20:37:15]
User344478 - Posts: 165
When I start Open Market Depth Window (OMDW) on laptop or on one of two additional monitors the three screens are freezing. When I remove OMDW Sierra Chart starts working again.
[2026-02-25 21:09:53]
There should be no connection between these items.
When you open the Market Depth window and the other screens freeze, does the Market Depth window continue to function properly? Does it continuously update the information in it?
What exactly is occurring on the other windows? What happens if you try to access them?
[2026-02-25 22:57:01]
NO.
NO.
I use Clock-Real Time from chart studies on each screen and when I start OMDW on laptop or on one of two additional monitors the three screens and Clock-Real Time are freezing. If I try to acsses them nothing happens.
Date Time Of Last Edit: 2026-02-26 02:57:27
[2026-02-26 14:15:26]
Please get us the chartbook that has this occurring, as we want to see if we can reproduce this with your chartbook. Follow these instructions to get us the file:
Also, we would like for you to close that chartbook, and then open a single new chart and then open the Market Depth Window, and let us know if you have the same issue with just that one chart.
[2026-03-02 23:36:45]
"C:\Users\Owner\Documents\Snagit\2026-03-02_18-20-15.mp4"
[2026-03-03 14:43:08]
Your last post is the path to a video file on your local computer.
We need the chartbook that you are having an issue with by following these instructions:
And also close all chartbooks and open a new chart and open the "Market Depth Window" and see if you have the same problem.
[2026-03-04 15:50:45]
I close all chartbooks and open a new chart and open the "Market Depth Window" and I have the same problem.
[2026-03-04 16:35:40]
Please get us a chartbook that shows this problem by following these instructions:
