Date/Time: Mon, 14 Jul 2025 21:12:52 +0000
s_SCNewOrder fields to use for a stop limit order
View Count: 1038
[2014-10-23 19:33:50] |
flyboy615 - Posts: 56 |
Hi, I use to use LimitPrice and Stop1Price to create stop limit orders for order entry. For some reason the has stopped working. In reading the documentation I'm no longer sure if those are the correct fields to use. Please advise. Thanks |
[2014-10-24 03:59:03] |
You need to use Price1 and Price2. LimitPrice and StopPrice are out of date.
