Date/Time: Tue, 27 Oct 2026 17:54:28 +0000
Data Required for SPX Options
View Count: 623
[2026-02-24 16:23:21]
User769783 - Posts: 208
Which data feed and market subscription is required to receive the limited options for SPX options? Thanks in advance.
[2026-02-24 16:52:55]
John - SC Support - Posts: 48342
We do not have data for SPX Options, as we do not have Options data for any of the U.S. Equities.
[2026-02-24 17:25:46]
But you do have limited access correct, in the past I had access to them. When I subscribed I could get access to certain strikes but only for the SPX and Crude. Or, what subscription would I need for numbers bars data and CME group products with full market depth. I believe this will allow me to get the data I'm looking for, thanks again.
[2026-02-24 18:53:59]
When you state SPX, we assumed you were referring to the "SPDR S&P 500 ETF" (SPY). For which we do not have options.
The actual SPX symbol refers to the S&P 500 Index calculated by the CBOE, which is not a traded product.
If you are referring to the CME Group futures, specifically the "S&P 500 Index Futures", which are represented by the ES and MES symbols, along with Crude Oil (CL and MCL), then we do have Options data for these. We have Options data for all the CME Group data.
[2026-02-24 19:31:26]
Yes, thank you for clarifying. What is the datafeed needed and which market subscription do I need, thanks again.
[2026-02-24 19:46:54]
If you do not need the real-time data, then you can get the data from our Delayed Streaming Data which is 10 minutes and 10 seconds behind the real-time data. In this case, you can be on any package, and you do not need anything in terms of the data, as the Delayed Streaming Data is available automatically at no cost for all packages.
If you do need real-time data, then you would need to be on one of the "Integrated" packages. But in terms of data, any exchange option for the specific exchange(s) for which you want the Options data would be required.
Refer to the following regarding packages:
Description of Service Packages and Pricing: Packages
Refer to the following for the exchange costs:
Denali Exchange Data Feed: Supported Exchanges (Exchange Fees)
