Date/Time: Thu, 26 Nov 2026 04:45:45 +0000
Maximize Minimize Button not showing after new update
View Count: 595
| [2026-02-24 08:49:36] |
| noumantrades - Posts: 14 |
Hello Support, I recently updated Sierra to the Feb version, and when I have two or three chart windows open side by side, I can see the max, min and close button at theright top but if I maximize one chart window, I don't see those buttons. Instead, I see them above my Control Bar. Please see the attached screenshot and let me know how do I fix this. Thank you |
| [2026-02-24 15:55:01] |
This is a change that has been made with the recent releases. You can control what is displayed for those items. Refer to the following and the three items below it: General Settings Window: MDI Container Window Child Window Menu Text Separator (Global Settings >> General Settings >> GUI >> Multiple Document Interface (MDI) and Custom Title Bar Settings) Also, you should look at the other settings in that section (Multiple Document Interface (MDI) and Custom Title Bar Settings) as there are a number of changes to the "MDI" windows (the windows that are attached to the main application), and there are those settings to control how they act/work. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-25 10:45:47] |
Thanks. But it won't be possible to see those buttons like before anymore?
| [2026-02-25 14:57:10] |
They are not displayed like they used to be. We have changed how those windows are controlled and that required a change to how those controls worked.
