Date/Time: Thu, 26 Nov 2026 03:19:26 +0000
Delta on candle
View Count: 392
[2026-02-20 17:25:08]
User643802 - Posts: 26
is there a study that show large delta and numbers on a candle like large volume trade study without needing a numbers bar study?
[2026-02-20 18:33:48]
What exactly are you looking for that is not in the "Large Volume Trade Indicator"?
You can use the "Large Volume Trade Indicator" without using the Numbers Bars study. If you thought this was the case, then we are curious where you got this information, so we can correct it if it is something we have alluded to somewhere.
[2026-02-20 18:51:27]
no i am asking if we have something like large volume trade indicator but displaying positive and negative delta instead of orders
Date Time Of Last Edit: 2026-02-20 18:52:44
[2026-02-20 18:55:33]
Large delta of what? Are you wanting to know the delta at each price level, and then only display a delta that is larger than a certain amount? And if so, what delta calculation - a straight calculation or a diagonal calculation?
Or is this per bar?
Or something else?
[2026-02-25 20:38:34]
just like large volume trade indicator, i want it to show large delta in each bar and amount. diagonal
[2026-02-25 21:22:23]
The only way to do what you are wanting is to use the "Numbers Bars" study and set the following:
- Text Type: One of "Ask Vol Bid Vol Difference Diagonal", "Ask Vol Bid Vol Diff Diagonal Bid Side", "Ask Vol Bid Vol Diff Diagonal Ask Side", or "Ask Vol Bid Vol Diff Diagonal Dominant Side".
- Bid/Ask Minimum Volume Compare Threshold: Set to the value above which you want the comparison to be done.
Other items should be set as you want them.
Refer to the following for these items:
Numbers Bars: Input Settings for Numbers Bars
