Date/Time: Wed, 25 Nov 2026 23:10:06 +0000
How to keep Denali data but use prop eval accounts for trading?
View Count: 499
[2026-02-20 04:17:44]
jethrogou - Posts: 56
Good day,
I have read the setup for prop accounts under rithmic and the workaround when doing evals but I am confused as to how to use rithmic account to trade while still using Denali data.
My question:
1. How to use denali data feed while trading prop firm eval accounts under rithmic?
Date Time Of Last Edit: 2026-02-20 04:24:37
imageMain Settings.png / V - Attached On 2026-02-20 04:23:51 UTC - Size: 42.35 KB - 154 views
imageCommon Settings.png / V - Attached On 2026-02-20 04:23:55 UTC - Size: 57.73 KB - 150 views
[2026-02-20 07:56:59]
User135243 - Posts: 337
If I read your header, you already have Denali realtime data set up (connected to a real live account), if yes, great your setup is perfect to route trades to Rithmic and use Denali realtime data.
[2026-02-20 14:34:59]
Refer to the following:
Denali Exchange Data Feed: Integration with Trading Services
[2026-02-20 14:39:21]
Thank you for your responses. I was able to fix the issue with the frozen data that I had encountered. I just needed to click "Translate Symbols To Current Service".
