Date/Time: Wed, 25 Nov 2026 23:10:08 +0000
Amp Futures Teton - Supported for Denali Data Feed Authorization?
View Count: 691
[2026-02-19 03:01:58]
CrocZilla - Posts: 6
Hello all,
I have a live funded AMP futures account and would use Teton Order Routing in Sierra Chart. AMP isn’t listed by name on the “supported trading services” list, so I want to confirm eligibility.
Does using Teton with AMP (as clearing firm) allow Sierra Chart to verify I have an active/capitalized live account and therefore qualify for CME non-professional real-time data on the Denali Exchange Data Feed?
If yes, do I need to do the “connect once every 30 days” check, or is it automatically authorized when using Teton?
Thanks,
[2026-02-19 05:11:25]
Sierra_Chart Engineering - Posts: 25485
Amp is supported, through Teton order routing:
Yes:
You do not need to connect every 30 days. The verification happens automatically.
[2026-02-19 13:04:10]
Thanks for the clarification — I missed the other documentation page at first.
I was reading this page:
Easy Solution to CME Funded Trading Account Requirement
On a first read, it wasn’t obvious to me that Stage 5 / Edge Clear / Cannon are just the recommended “easy solution” options, and that there are other supported trading services used for CME non-pro verification/Denali integration.
If you think it’s appropriate, a small link or note on that page pointing to the supported services/integration documentation could help avoid confusion for others. Sierra Chart Teton Futures Order Routing: Setup Instructions
Thanks again,
Mike
