Date/Time: Wed, 25 Nov 2026 23:10:07 +0000
New Trial - Enable Package 5 for numbers bars
View Count: 553
| [2026-02-18 14:51:48] |
| deko889 - Posts: 1 |
Hi, Username:JHONWIL New trial created yesterday. Number bars chart is black/blank after duplicate and apply. In account control panel, only "service for brokers" show - no set service Package option. Please enable package 5 advanced for free in my trial to test order flow. Thanks |
| [2026-02-18 15:34:04] |
While on a trial you have the full capabilities of the system, except for the ability to connect to data and trading services, and a limitation on the data available. Therefore, the Numbers Bars study is available and should work as long as you are using the correct data. Refer to the following for the information on what data you have available during a trial: Sierra Chart Trial Account If you want to change to a paid package, then you would need to actually add the funds and purchase the package. To do this, follow the instructions at the following link: Sierra Chart Purchase and License Information: Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
