Date/Time: Wed, 25 Nov 2026 23:10:09 +0000
Flatten and Cancel at Set Time Triggering while disabled
View Count: 500
[2026-02-17 21:31:46]
ianm44 - Posts: 4
For some time now, I've been dealing with an issue where all positions in my account flatten at 1541EST. I've been primarily paper trading, and regardless of the paper account I'm using, the same issue occurs. I've checked global settings and A trade settings across accounts and charts - all "flatten & cancel" options are checked to disabled. Please advise. Thanks in advance!
[2026-02-17 22:18:58]
Within the Sierra Chart software there are two places that a "Flatten and Cancel at Set Time" can be setup. Refer to the following:
Basic Trading and the Trade Window: A >> Flatten And Cancel at Set Time
Global Profit/Loss Management: Flatten Positions at Set Time
And it looks like you are using the Trading Evaluator for your simulated trading, in which case there is a way to set this for that option as well. Refer to the following instructions for adjusting margins for a Trading Evaluator account:
Simulated Futures Trading Service: Margin Requirement Adjustments
Follow those instructions but at Step #4 go to the "User Profit/Loss Management" tab and find the section for "Flatten Positions at Time".
[2026-02-18 14:14:23]
ianm44 - Posts: 4
Thanks for the response! I went through the above and can confirm that there are no settings in place to Flatten at Set Time on any of the evaluator accounts in user P/L management or Global P/L management. Still unsure what's causing this auto-flatten.
[2026-02-18 14:27:33]
Sierra_Chart Engineering - Posts: 25485
You need to check for the origin of the order, which is closing the position. Refer to:
Trade Activity Log Analysis: Determining the Origin of a New/Modified Order
[2026-02-18 14:45:23]
ianm44 - Posts: 4
I've attached a screenshot of the log at the 1541 TransDateTime. All highlighted rows, IsAutomated = Y. It looks like Flatten and Cancel at Set Time is triggered, but again, this is not the case in my settings and has been ongoing for months. Worth noting at one point I did have Flatten and cancel at set time at 1541 enabled. If you want me to upload the full Trade Activity log, I'm happy to do so. Hope this is helpful.
imageScreenshot 2026-02-18 074045.jpg / V - Attached On 2026-02-18 14:41:03 UTC - Size: 477.34 KB - 157 views
[2026-02-18 14:59:11]
This is definitively the result of a Trade Window from one of the open charts having this set:
There is simply no other possibility.
This definitively cannot be true:
Date Time Of Last Edit: 2026-02-18 14:59:43
[2026-02-18 15:31:50]
ianm44 - Posts: 4
You're absolutely right - I dug deeper, and the setting was hiding in a chart I rarely use. Thanks for taking the time to reply.
