Date/Time: Wed, 25 Nov 2026 23:10:14 +0000
Performance of Numbers Bars Study - Benchmarks?
View Count: 697
[2026-02-17 01:28:51]
User273277 - Posts: 145
The Numbers Bars study consistently adds 25ms to my Average Calculation and Draw Time in the Performance tab of the Chart Settings window. The VBP study also runs at 10ms, but I'm less concerned about that one.
I have seen other threads regarding Numbers Bars and overall Sierra performance improvements like these:
Performance Problems with Numbers Bars
Recommendations to Improve Overall Sierra Chart Performance
I have tested and changed tick size, number of days to display, removed all unused studies, tested OpenGL on/off, and am using a stripped down Windows install.
The machine has 24 CPU threads, 64GB ecc ram, NVMe storage. I have tested different Nvidia and AMD GPU's, though older generations. CPU performance is about 20% off the fastest single core geekbench. The CPU cores usually peak in single digit usage, and GPU hits 30% with this study and OpenGL enabled.
I have other charts with dozens of all kinds of built in studies, alerts, spreadsheets, and custom compiled code, and they all run fast. ie. Charts with 10, 20, 50 studies, run at 6ms, 10ms, 15ms.
If I run one chart, with just the Numbers Bars study, it runs at 25ms.
This is at full screen 4k resolution. The draw time improves the smaller the window is.
I would happily upgrade the CPU to get the last 20% of silicon performance, or the GPU if a generational upgrade makes a huge difference with these calculations. But seeing as the performance is isolated to 1-2 studies, and is 10x to >25x slower then any other study I use, this seems more like an optimization issue in the study code, or user control.
Any ideas, or benchmarks of drawtime at 4k with the numbers bars study with different cpu/gpu combinations out there?
[2026-02-17 03:46:08]
Sierra_Chart Engineering - Posts: 25485
Numbers Bars involves a lot of text and text is simply inefficient. If you remove the text that will make a difference.
The problem is the text, and the use of a 4K monitor.
Date Time Of Last Edit: 2026-02-17 03:46:18
[2026-02-19 07:50:08]
In the "Numbers Bars" study, I removed the column 1 and column 2 numbers by setting "Column 1 Numbers Bars Text" to "None", and also "Column 2 Numbers Bars Text" to "None".
There was no change to the Average Calculation and Draw Time in the Performance tab of the Chart Settings window.
It looks like hiding the text in the study still has the text being drawn in the background somewhere?
If I hide the "Numbers Bars" study, the time drops significantly.
[2026-02-19 07:50:27]
Side note.
If I understand correctly, depending on exactly which methods are being used, OpenGL text relies heavily on pixel/texture fill rates, and memory bandwidth.
I generated a table with an Nvidia RTX 4060 as baseline, ordered by combined improvement.
It looks like text drawing performance could be 3-6x better with the latest hardware.
GPU  Pixel Fill Rate (GPixel/s)  Texture Fill Rate (GTexel/s)  Memory Bandwidth (GB/s)  Multiplier vs. RTX 4060 (approx.)
RTX 4060  118  236  272  1× (baseline)
RTX 5060  120  300  448  ~1× fill rates, ~1.65× bandwidth
RTX 5070 Ti  235  687  896  ~2× fill rates, ~3.3× bandwidth
RX 7700 XT  244  550  432  ~2.1× fill rates, ~1.6× bandwidth (effective higher w/ Infinity Cache)
RX 9070    323  564  640  ~2.7× fill rates, ~2.35× bandwidth
RTX 5080  293  879  960  ~2.5× fill rates, ~3.5× bandwidth
RX 9070 XT  380  760  640  ~3.2× fill rates, ~2.35× bandwidth
RTX 5090  424  1637  1792  ~3.6× fill rates, ~6.6× bandwidth
I know this is a ridiculously niche question, but does this hardware performance difference match what users are seeing real world for numbers bars calculation at 4k?
[2026-02-20 22:29:25]
We just did a quick test now, under our debugger, and we do see the draw time for Numbers Bars go down by about 50%, when not displaying text within Numbers Bars. You cannot have a very dense display of text with so many individual text drawings, and then remove it and it makes no timing difference. It has to make a difference.
If it does not, well that would be good but it is not logical.
[2026-02-21 23:09:58]
I agree it should make a difference.
Please see the attached video where I set both column 1 and 2 text to "None" in the Numbers Bars study, and there is no change to draw time.
The chart is zoomed out to exaggerate the draw time.
Attached is a second video where hiding the study results in the expected large draw time reduction.
Maybe it is something I am doing?
Private File
Private File
[2026-02-23 16:28:08]
I updated video drivers. OpenGL rendering improved a lot. From 40-45ms to 15ms consistently.
I have never seen such a tripling in performance from a driver update.
I don't know if it's AMD, OpenGL, or the combination with the specific calls Sierra uses to render text, but using the latest drivers seems extra important here.
