Date/Time: Wed, 25 Nov 2026 23:00:10 +0000
rithmic data permissions CME
View Count: 441
| [2026-02-16 17:57:01] |
| User993067 - Posts: 200 |
I have denali data for broker acct with nymex permissions....but also have apex acct...not getting CME data on rithmic feed...is there some permission setting i am missing?...i recall sometime prior same issue and I had to click OK somewhere..to receive the data...not sure where?
| [2026-02-16 18:55:47] |
| Sierra_Chart Engineering - Posts: 25484 |
We cannot help with this: not getting CME data on rithmic feed...is there some permission setting i am missing?..
We recommend, activating the CME exchange here for the easiest solution: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to Yes. If you have changed this setting, then reconnect to the data feed after by selecting 'File >> Reconnect". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-02-16 18:57:13
