Date/Time: Wed, 25 Nov 2026 23:00:12 +0000
How to set the numbers bar column background based on the volume over all bars
View Count: 355
[2026-02-15 01:40:28]
User447011 - Posts: 7
Is there a method to fill the numbers bar column background color based on the volume over all bars, instead of single bar. For example, in the figure below, at 15:36:40, the largest volume is 107+118 = 225, but the previous bar the largest volume is 42 + 53 = 97. They are shown with the same color and same background, which might be misleading while comparing across bars. Is it possible to emphasize the 225 volume?
image微信图片_20260214203933_151_2.png / V - Attached On 2026-02-15 01:39:59 UTC - Size: 118.67 KB - 210 views
[2026-02-16 15:45:46]
There is not an option to have the coloring based on the volumes of all bars.
There is the following option which will change the length of the bars, but again, not the color:
Numbers Bars: Volume Profile Bars Length Relative to All Visible Bars
