Date/Time: Mon, 23 Nov 2026 12:24:26 +0000
Windows and Tabs
View Count: 779
| [2026-02-13 14:59:00] |
| rondawes - Posts: 54 |
Am I correct in that windows detached from the main window cannot have tabs like the main window? I have three monitors and I'd like to have a window in each that has tabs for other charts. Will that require that I run aN instance of SC for each monitor? Thanks
| [2026-02-13 15:37:18] |
| John - SC Support - Posts: 48610 |
This is correct. When a window is "detached" it is then managed by the operating system, which is why you will see an icon for it in your Taskbar instead of the tab in the application. I have three monitors and I'd like to have a window in each that has tabs for other charts. Will that require that I run aN instance of SC for each monitor?
If you want to have the window with the tabs in each monitor, then yes, you would need to run additional instances and have one for each monitor. Refer to the following for information on Sub-Instances: File Menu: New Instance (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-13 16:29:33] |
Thanks John. I'm not a fan of NT, and SC is far superior in many, many ways but the way they handle windows/tabs has some advantages.
| [2026-02-13 17:29:51] |
| Sierra_Chart Engineering - Posts: 25463 |
This feature is coming: Am I correct in that windows detached from the main window cannot have tabs like the main window? I have three monitors and I'd like to have a window in each that has tabs for other charts.
| [2026-02-13 19:13:39] |
Great, looking forward to it.
| [2026-04-02 16:43:53] |
Is there an approximate time that this feature will be released? Thanks
| [2026-04-02 17:43:39] |
We do not give timing on when features will be ready, as too many things come up that always push it out. We can state that this item is under active development. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-03 07:10:09] |
We intend to complete this, this year.
| [2026-10-27 20:53:02] |
Hi, is this still on track for this year? Thanks! |
| [2026-10-28 02:53:16] |
No definitely not this year. It will be next year and we will try but not promise that it will be before the middle of 2027. This is involved. It is not a simple task. What this is about, is multiple main MDI container windows. Where every Chartbook has its own window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
