Date/Time: Tue, 13 Oct 2026 16:42:31 +0000
Realm time market data
View Count: 327
| [2026-02-12 20:20:42] |
| Tin43 - Posts: 164 |
Sorry. I look for this answer and I can understand the info. I got a service 10 package. What I want is to see real time data. I activate Denali data feed etc. I got Bookmap with real time data. Difference is 10 minutes delayed for Sierra. How can i solve this? Thanks in advance. |
| [2026-02-12 20:35:20] |
| John - SC Support - Posts: 48189 |
What are the exchanges for which you are wanting real-time data?
| [2026-02-12 20:53:19] |
CME!
| [2026-02-12 21:12:31] |
If you have a brokerage account with Interactive Brokers, or a Futures Broker that uses Rithmic for the order routing, then you can get the data from them. If you want to get the data from our Denali Exchange Data Feed, then to get the CME Group data at the Non-Professional rates, you need to have a live, funded, futures trading account. And you need to connect your Sierra Chart software to that account at least once a month for verification. Refer to the following: Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Once you have the above worked out, then you can setup the data by following these instructions: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-12 21:28:14] |
Thanks!!!
