Date/Time: Wed, 25 Nov 2026 23:00:18 +0000
Charts Minimized & Tile Vertically
View Count: 439
| [2026-02-12 16:45:15] |
| User303857 - Posts: 201 |
Hello, what has happened to the charts not staying minimized? Used to be able to have several windows minimized and able to tile the rest vertically. Now they stay on screen in small boxes and then when tiled , they all restore. Is there way to revert all chart books to the older settings , where windows remain minimized and tile the others as needed? The order is all scrambled now, they all open and not as previously laid out & saved. What has happened to the settings now for keeping the charts organized? How do you keep windows minimized and out of view? Thanks Date Time Of Last Edit: 2026-02-12 16:51:02
| [2026-02-12 19:01:20] |
First, please update to the latest version to ensure you have all the recent changes. Update by following these instructions: Software Download: Fast Update Then the windows should work correctly going forward. There are a number of controls related to how the charts that are contained within the main application can function. Refer to the following and the rest of the items in the section for "Multiple Document Interface": General Settings Window: Multiple Document Interface (MDI) and Custom Title Bar Settings (Global Settings >> General Settings >> GUI) In particular, note the item for "MDI Child Window Minize Method". Right now, it is probably set to "Minimize In Place". The functionality as it used to be would be if this was set to "Minimize to Bottom". Although the option for "Hide Window" actually works quite well. So look through the options and see what works best for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
