Date/Time: Wed, 25 Nov 2026 23:00:16 +0000
study search function
View Count: 403
| [2026-02-10 08:15:50] |
| User354816 - Posts: 24 |
With the amount of studies, it can sometimes be really annoying when you're looking for one specific study. Would it be possible for you to implement a search function in the study selection?
| [2026-02-10 16:12:01] |
What exactly are you looking for within the study selection window? You can search through the names of the studies at the following link: Technical Studies Reference And if you want to search through the descriptions for the studies, you can either use our website "Search" function (upper right corner of the website pages), your can use a Google search to search just the Technical Studies pages, then you can use the following in conjunction with your search terms: +site:https://www.sierrachart.com/index.php?page=doc/StudiesReference.php For example, to search for "moving average", you would use the following: moving average +site:https://www.sierrachart.com/index.php?page=doc/StudiesReference.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-02-10 18:43:20] |
| Sierra_Chart Engineering - Posts: 25484 |
This is planned to be added.
| [2026-02-10 18:55:15] |
Thank you ! Would be nice if the function will also search in every (sub-)folder from the custom studies. |
