Date/Time: Wed, 25 Nov 2026 23:00:19 +0000
volume profile lines
View Count: 418
[2026-02-09 20:07:26]
User538826 - Posts: 11
HI
i have set two VP for each session within one day. As you can see the VA are moving diagonally. i have had a tweak with the settings but cannot seem to fix it even if the extension lines are set to non. i have also set itt o end of period but not sure why it still is not sorting out. see attached pictures of the issue and the settings.
imageScreenshot 2026-02-07 183104.png / V - Attached On 2026-02-09 20:07:13 UTC - Size: 117.45 KB - 223 views
imageScreenshot 2026-02-07 183042.png / V - Attached On 2026-02-09 20:07:16 UTC - Size: 167.97 KB - 206 views
imageScreenshot 2026-02-07 183020.png / V - Attached On 2026-02-09 20:07:19 UTC - Size: 169.31 KB - 200 views
imageScreenshot 2026-02-07 182532.png / V - Attached On 2026-02-09 20:07:22 UTC - Size: 440.79 KB - 184 views
[2026-02-09 20:08:21]
If you are referring to the connecting lines for the Value Area lines from one profile to the next, then change the "Draw Style" for the Value Area High and Value Area Low to be "Dash". Refer to the following:
Chart Studies: Dash (ACSIL: DRAWSTYLE_DASH)
