Date/Time: Fri, 26 Apr 2024 18:10:48 +0000
Not evaluating trade signals because 10 or more bars have been a
View Count: 1494
[2013-05-14 09:14:57] |
fxz - Posts: 32 |
Hi how to ignore this error and place orders either when more than 10 bar added at once? Trade Service Log: Spreadsheet System for Trading: EURUSD 1 tick #3 | Spreadsheet: EU_1 | Not evaluating trade signals because 10 or more bars have been added at once. | 2013-05-14 09:11:28 |
[2013-05-14 17:49:46] |
It would probably be easiest for us just to increase the limit. This is an older safety check that really is not needed because of other safety checks. In your case, how many bars are being added between chart updates? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-14 18:19:56] |
fxz - Posts: 32 |
personally 20 max ticks at once it s happening (frequently) just on version > 970 with 959 doesn t happen (never) i have also another error on rel. >970 to avoid errors tried upgrading straight from help->download current version the working 959 to 975, cnx certs moved to \data, connection fine , manual trading fine, "randomly" these 2 errors when spreadsheet sustem autotrading (first error it changes the quantity to 1 which obv. is rejecyed by datafeeder server, the 2nd error (subject of this topic) it doesn t arrive to stage of placing due due >10 bars issue ) log 1st error log Trade Order Error - Currenex order update (Rejected). Info: invalid amount. Internal Order ID: 1483. Symbol: EURUSD | 2013-05-14 16:57:30 2nd error log Spreadsheet System for Trading: EURUSD 1 tick #3 | Spreadsheet: EU_CNX_1 | Not evaluating trade signals because 10 or more bars have been added at once. | 2013-05-14 16:57:38 |
[2013-05-14 22:19:18] |
We have increased the number of bars added during an update before an error is given with automated trading. So this is solved. The Order Quantity when using the Spreadsheet Trading study, is strictly now controlled through the J26 cell. Always make certain that is set correctly: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#CellJ26 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-23 23:47:54] |
Please update to the latest version of Sierra Chart by selecting Help >> Download Prerelease. You should not encounter this trade error with newer versions. If you are having trouble connecting to TransAct, start a new Support Request and post a copy of the Message Log, by following the instructions here: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
