Date/Time: Wed, 25 Nov 2026 23:00:18 +0000
horizontal line set default width
View Count: 412
[2026-02-09 19:37:13]
Litz - Posts: 135
is this possible ?
[2026-02-09 23:09:21]
What exactly do you want to do? What Horizontal Line are you referring to? Is this the Drawing Tool, or study?
[2026-02-10 00:48:49]
Litz - Posts: 135
The horizontal line tool. Each time I place a line I must adjust it's width from the dropdown. Its a pita
[2026-02-10 15:21:59]
This is what the Configurations for the Drawing Tools are for. Refer to the following:
Chart Drawing Tools: Drawing Tool Configuration
Refer to the following for how to select a tool and configuration using a control bar button/keyboard shortcut:
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
[2026-02-11 00:56:27]
Litz - Posts: 135
OK FOUBD THE ADJUSTMENT TOOL TNX
