Date/Time: Wed, 25 Nov 2026 23:00:17 +0000
Version 2878 major bug
View Count: 580
[2026-02-08 03:39:36]
nicktrader - Posts: 817
After updating and restarting, perhaps 5-10 seconds pass and the platform closes again immediately.
Back to 2877 and everything runs satisfactorily.
[2026-02-08 05:12:41]
Sierra_Chart Engineering - Posts: 25484
Are you using any custom studies?
We do not observe any problem like this.
Date Time Of Last Edit: 2026-02-08 05:13:01
[2026-02-08 06:04:03]
Yes, I do
[2026-02-08 17:43:41]
See if the problem goes away, when you run Sierra Chart in Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
[2026-02-08 18:00:38]
No change. Shutdown as before...
I always start with the “Open Files on Startup” box checked.
Without the box checked (and not in Safe Mode), there is no issue, and there is also no issue when I then open the stored chartbook in "Startup".
Date Time Of Last Edit: 2026-02-08 18:03:35
[2026-02-08 18:08:15]
We want you to go to the \CrashReports subfolder in the Sierra Chart installation folder. Do you see a new file created there, with the date and time, of when this problem occurs?
[2026-02-08 18:13:00]
There is a "SierraChart.17588.dmp" from today 18:51
Date Time Of Last Edit: 2026-02-08 18:15:23
[2026-02-08 18:16:52]
Perfect. Can you zip that file and attach it here, privately.
[2026-02-08 18:21:27]
see attached
Private File
[2026-02-08 18:23:05]
Thank you. We are checking.
[2026-02-08 18:25:33]
We are fixing this now. Just give us about 45 minutes for a release or so.
