Date/Time: Wed, 25 Nov 2026 22:50:06 +0000
Best way to copy trade using with Prop Firms
View Count: 1658
[2026-02-06 19:30:52]
User158338 - Posts: 6
I had one Funded and two Flex Eval accounts, all 50k account. I traded MSIL, I was up 1k on all accounts. I then tried to close out. But only one eval account closed. I used Rithimic. How should I go about using Sierra Chart with Prop firms. If I’m trading multiple accounts
[2026-02-06 19:33:53]
For what we have available for copying trades, refer to the following:
Order Allocation to Trade Accounts
If you are stating that you were using this feature, but the orders to close out were not copied, then you would need to look at your "Trade Activity Log" and look at the Orders specifically, and see if there were orders for all the accounts to close that position. Most likely the orders were sent from Sierra Chart - in which case the issue would be with how Rithmic processed these (or did not process them). We can not help with Rithmic related issues.
Refer to the following for how to find the orders:
Trade Activity Log Analysis: Determining the Origin of a New/Modified Order
Date Time Of Last Edit: 2026-02-06 19:34:18
