Date/Time: Tue, 17 Nov 2026 18:09:07 +0000
updated my credit today after being stuck in delayed data
View Count: 421
[2026-02-02 23:50:31]
User655290 - Posts: 2
I updated my credit info today and got an email saying they received the payment. However charts will not load and I can not get to anything on the chart to change data setting because all charts are just in spin mode. When I click on the chart they all go grey or invisib2026-02-02 17:20:55.291 | Trade activity files set size: 101
2026-02-02 17:20:55.374 | Created the DTC Protocol server.
2026-02-02 17:20:55.375 | DTC Protocol Server listening on port 11112. Address: 0.0.0.0
2026-02-02 17:20:55.375 | Reading Internal Order ID file.
2026-02-02 17:20:55.387 | Reading Trade Orders file.
2026-02-02 17:20:55.387 | Reading Trade Positions file.
2026-02-02 17:20:55.388 | Reading Trade Account Data files.
2026-02-02 17:20:55.390 | UDPListener (1780). Port 22903 | Error binding to UDP port: 22903. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted.
2026-02-02 17:20:55.397 | Software version: 2870 64-bit
2026-02-02 17:20:55.397 | Sub Instance
2026-02-02 17:20:55.397 | Primary Thread ID: 14768
2026-02-02 17:20:55.397 | Usage end date: 2026-02-21
2026-02-02 17:20:55.397 | Enabled for: Sierra Chart Historical Data Service.
2026-02-02 17:20:55.397 | Enabled for: Denali Real-Time Exchange Data Feed.
2026-02-02 17:20:55.397 | Enabled for: Delayed Denali Exchange Data Feed.
2026-02-02 17:20:55.397 | Allow Support for Sierra Chart Data Feeds is enabled.
2026-02-02 17:20:55.397 | Current selected Data/Trading service: DTC - Sub Instance
2026-02-02 17:20:55.397 | Custom symbol settings values: disabled
2026-02-02 17:20:55.397 | Chart Update Interval: 400
2026-02-02 17:20:55.397 | Intraday Data Storage Time Unit: 0
2026-02-02 17:20:55.397 | Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00)
2026-02-02 17:20:55.397 | 2026-02-02 23:20:55 Local computer time in UTC
2026-02-02 17:20:55.397 | 2026-02-02 17:20:55 Local computer time in SC Time Zone
2026-02-02 17:20:55.397 | 2026-02-02 23:20:54 Server time in UTC
2026-02-02 17:20:55.397 | Local computer UTC time and Server UTC time difference: 0 seconds.
2026-02-02 17:20:55.397 | Program path: C:\SierraChart\SierraChartTransActMA\SierraChartInstance_3\
2026-02-02 17:20:55.397 | Data Files path: C:\SierraChart\SierraChartTransActMA\SierraChartInstance_3\Data\
2026-02-02 17:20:55.397 | OS Version Number: 10.0
2026-02-02 17:20:55.397 | Locale Setting: C
2026-02-02 17:20:55.397 | Crash reporter started: true
2026-02-02 17:20:55.397 | Created the DTC Protocol historical data server.
2026-02-02 17:20:55.398 | HD Server Manager | Listening on port 11111.
2026-02-02 17:20:55.400 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2026-02-02 17:20:55.438 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2026-02-02 17:20:55.438 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2026-02-02 17:20:55.559 | Received 5 login tokens.
2026-02-02 17:20:57.890 | Requested user files to download.
2026-02-02 17:20:59.888 |
2026-02-02 17:20:59.889 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:20:59.889 | DTC Client socket (1) | Creating socket.
2026-02-02 17:20:59.889 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:20:59.889 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:20:59.890 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:20:59.890 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:20:59.890 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:21:19.900 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:21:19.900 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:21:19.900 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:21:19.916 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:21:19.916 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:21:19.916 | DTC - Sub Instance | Disconnected.
2026-02-02 17:21:19.916 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:21:19.916 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-02-02 17:21:21.931 |
2026-02-02 17:21:21.931 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:21:21.931 | DTC Client socket (2) | Creating socket.
2026-02-02 17:21:21.931 | DTC Client socket (2) | New receive buffer size: 0
2026-02-02 17:21:21.931 | DTC Client socket (2) | Connecting to IP: 127.0.0.1.
2026-02-02 17:21:21.933 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:21:21.933 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:21:21.933 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:21:41.932 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:21:41.932 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:21:41.932 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:21:41.948 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:21:41.948 | DTC Client socket (2) | CloseSocket call.
2026-02-02 17:21:41.948 | DTC - Sub Instance | Disconnected.
2026-02-02 17:21:41.948 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:21:41.948 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-02-02 17:21:43.950 |
2026-02-02 17:21:43.950 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:21:43.950 | DTC Client socket (3) | Creating socket.
2026-02-02 17:21:43.950 | DTC Client socket (3) | New receive buffer size: 0
2026-02-02 17:21:43.950 | DTC Client socket (3) | Connecting to IP: 127.0.0.1.
2026-02-02 17:21:43.951 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:21:43.951 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:21:43.952 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:22:04.008 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:22:04.008 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:22:04.008 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:22:04.021 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:22:04.022 | DTC Client socket (3) | CloseSocket call.
2026-02-02 17:22:04.022 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2026-02-02 17:22:04.022 | DTC - Sub Instance | Disconnected.
2026-02-02 17:22:04.022 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:22:06.022 |
2026-02-02 17:22:06.022 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:22:06.022 | DTC Client socket (4) | Creating socket.
2026-02-02 17:22:06.022 | DTC Client socket (4) | New receive buffer size: 0
2026-02-02 17:22:06.022 | DTC Client socket (4) | Connecting to IP: 127.0.0.1.
2026-02-02 17:22:06.023 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:22:06.023 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:22:06.023 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:22:26.012 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:22:26.012 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:22:26.012 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:22:26.041 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:22:26.041 | DTC Client socket (4) | CloseSocket call.
2026-02-02 17:22:26.041 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2026-02-02 17:22:26.042 | DTC - Sub Instance | Disconnected.
2026-02-02 17:22:26.042 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:22:28.048 |
2026-02-02 17:22:28.048 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:22:28.048 | DTC Client socket (5) | Creating socket.
2026-02-02 17:22:28.048 | DTC Client socket (5) | New receive buffer size: 0
2026-02-02 17:22:28.048 | DTC Client socket (5) | Connecting to IP: 127.0.0.1.
2026-02-02 17:22:28.049 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:22:28.049 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:22:28.049 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:22:48.053 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:22:48.053 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:22:48.053 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:22:48.065 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:22:48.065 | DTC Client socket (5) | CloseSocket call.
2026-02-02 17:22:48.065 | DTC - Sub Instance | Disconnected.
2026-02-02 17:22:48.065 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:22:48.066 | DTC Client socket (5) | Shutdown started. Waiting for graceful close.
2026-02-02 17:22:50.063 |
2026-02-02 17:22:50.064 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:22:50.064 | DTC Client socket (6) | Creating socket.
2026-02-02 17:22:50.064 | DTC Client socket (6) | New receive buffer size: 0
2026-02-02 17:22:50.064 | DTC Client socket (6) | Connecting to IP: 127.0.0.1.
2026-02-02 17:22:50.065 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:22:50.065 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:22:50.065 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:23:10.066 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:23:10.066 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:23:10.066 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:23:10.081 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:23:10.082 | DTC Client socket (6) | CloseSocket call.
2026-02-02 17:23:10.082 | DTC - Sub Instance | Disconnected.
2026-02-02 17:23:10.082 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:23:10.082 | DTC Client socket (6) | Shutdown started. Waiting for graceful close.
2026-02-02 17:23:12.078 |
2026-02-02 17:23:12.078 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:23:12.078 | DTC Client socket (7) | Creating socket.
2026-02-02 17:23:12.078 | DTC Client socket (7) | New receive buffer size: 0
2026-02-02 17:23:12.078 | DTC Client socket (7) | Connecting to IP: 127.0.0.1.
2026-02-02 17:23:12.079 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:23:12.079 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:23:12.079 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:23:19.920 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:23:19.920 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-02-02 17:23:19.920 | DTC Client socket (1) | Closed.
2026-02-02 17:23:32.078 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:23:32.078 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:23:32.078 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:23:32.094 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:23:32.094 | DTC Client socket (7) | CloseSocket call.
2026-02-02 17:23:32.094 | DTC Client socket (7) | Shutdown started. Waiting for graceful close.
2026-02-02 17:23:32.094 | DTC - Sub Instance | Disconnected.
2026-02-02 17:23:32.094 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:23:34.090 |
2026-02-02 17:23:34.090 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:23:34.090 | DTC Client socket (1) | Creating socket.
2026-02-02 17:23:34.090 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:23:34.090 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:23:34.092 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:23:34.092 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:23:34.092 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:23:41.962 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:23:41.962 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-02-02 17:23:41.962 | DTC Client socket (2) | Closed.
2026-02-02 17:23:54.093 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:23:54.093 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:23:54.093 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:23:54.109 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:23:54.109 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:23:54.109 | DTC - Sub Instance | Disconnected.
2026-02-02 17:23:54.109 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:23:54.109 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-02-02 17:23:56.114 |
2026-02-02 17:23:56.114 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:23:56.114 | DTC Client socket (2) | Creating socket.
2026-02-02 17:23:56.114 | DTC Client socket (2) | New receive buffer size: 0
2026-02-02 17:23:56.115 | DTC Client socket (2) | Connecting to IP: 127.0.0.1.
2026-02-02 17:23:56.116 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:23:56.116 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:23:56.116 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:24:04.030 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-02-02 17:24:04.030 | DTC Client socket (3) | Closed.
2026-02-02 17:24:16.112 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:24:16.112 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:24:16.112 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:24:16.128 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:24:16.128 | DTC Client socket (2) | CloseSocket call.
2026-02-02 17:24:16.128 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-02-02 17:24:16.128 | DTC - Sub Instance | Disconnected.
2026-02-02 17:24:16.128 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:24:18.121 |
2026-02-02 17:24:18.121 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:24:18.121 | DTC Client socket (3) | Creating socket.
2026-02-02 17:24:18.122 | DTC Client socket (3) | New receive buffer size: 0
2026-02-02 17:24:18.122 | DTC Client socket (3) | Connecting to IP: 127.0.0.1.
2026-02-02 17:24:18.123 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:24:18.123 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:24:18.123 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:24:26.041 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:24:26.041 | DTC Client socket (4) | Socket gracefully closed by remote side.
2026-02-02 17:24:26.042 | DTC Client socket (4) | Closed.
2026-02-02 17:24:38.130 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:24:38.130 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:24:38.130 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:24:38.146 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:24:38.146 | DTC Client socket (3) | CloseSocket call.
2026-02-02 17:24:38.147 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2026-02-02 17:24:38.147 | DTC - Sub Instance | Disconnected.
2026-02-02 17:24:38.147 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:24:40.142 |
2026-02-02 17:24:40.142 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:24:40.143 | DTC Client socket (4) | Creating socket.
2026-02-02 17:24:40.143 | DTC Client socket (4) | New receive buffer size: 0
2026-02-02 17:24:40.143 | DTC Client socket (4) | Connecting to IP: 127.0.0.1.
2026-02-02 17:24:40.144 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:24:40.144 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:24:40.144 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:24:48.073 | DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:24:48.073 | DTC Client socket (5) | Socket gracefully closed by remote side.
2026-02-02 17:24:48.073 | DTC Client socket (5) | Closed.
2026-02-02 17:25:00.140 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:25:00.140 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:25:00.140 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:25:00.157 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:25:00.157 | DTC Client socket (4) | CloseSocket call.
2026-02-02 17:25:00.157 | DTC - Sub Instance | Disconnected.
2026-02-02 17:25:00.157 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:25:00.157 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2026-02-02 17:25:02.156 |
2026-02-02 17:25:02.156 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:25:02.156 | DTC Client socket (5) | Creating socket.
2026-02-02 17:25:02.156 | DTC Client socket (5) | New receive buffer size: 0
2026-02-02 17:25:02.156 | DTC Client socket (5) | Connecting to IP: 127.0.0.1.
2026-02-02 17:25:02.158 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:25:02.158 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:25:02.158 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:25:10.085 | DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:25:10.085 | DTC Client socket (6) | Socket gracefully closed by remote side.
2026-02-02 17:25:10.085 | DTC Client socket (6) | Closed.
2026-02-02 17:25:22.162 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:25:22.162 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:25:22.162 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:25:22.178 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:25:22.178 | DTC Client socket (5) | CloseSocket call.
2026-02-02 17:25:22.178 | DTC Client socket (5) | Shutdown started. Waiting for graceful close.
2026-02-02 17:25:22.178 | DTC - Sub Instance | Disconnected.
2026-02-02 17:25:22.178 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:25:24.177 |
2026-02-02 17:25:24.177 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:25:24.177 | DTC Client socket (6) | Creating socket.
2026-02-02 17:25:24.177 | DTC Client socket (6) | New receive buffer size: 0
2026-02-02 17:25:24.177 | DTC Client socket (6) | Connecting to IP: 127.0.0.1.
2026-02-02 17:25:24.178 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:25:24.178 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:25:24.178 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:25:32.097 | DTC Client socket (7) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:25:32.097 | DTC Client socket (7) | Socket gracefully closed by remote side.
2026-02-02 17:25:32.097 | DTC Client socket (7) | Closed.
2026-02-02 17:25:44.168 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:25:44.168 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:25:44.168 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:25:44.183 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:25:44.184 | DTC Client socket (6) | CloseSocket call.
2026-02-02 17:25:44.184 | DTC - Sub Instance | Disconnected.
2026-02-02 17:25:44.184 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:25:44.184 | DTC Client socket (6) | Shutdown started. Waiting for graceful close.
2026-02-02 17:25:46.193 |
2026-02-02 17:25:46.193 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:25:46.193 | DTC Client socket (7) | Creating socket.
2026-02-02 17:25:46.194 | DTC Client socket (7) | New receive buffer size: 0
2026-02-02 17:25:46.194 | DTC Client socket (7) | Connecting to IP: 127.0.0.1.
2026-02-02 17:25:46.195 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:25:46.195 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:25:46.195 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:25:54.121 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:25:54.121 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-02-02 17:25:54.121 | DTC Client socket (1) | Closed.
2026-02-02 17:26:06.185 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:26:06.185 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:26:06.185 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:26:06.201 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:26:06.201 | DTC Client socket (7) | CloseSocket call.
2026-02-02 17:26:06.201 | DTC - Sub Instance | Disconnected.
2026-02-02 17:26:06.201 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:26:06.201 | DTC Client socket (7) | Shutdown started. Waiting for graceful close.
2026-02-02 17:26:08.200 |
2026-02-02 17:26:08.200 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:26:08.200 | DTC Client socket (1) | Creating socket.
2026-02-02 17:26:08.200 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:26:08.200 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:26:08.201 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:26:08.201 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:26:08.202 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:26:16.140 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:26:16.140 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-02-02 17:26:16.140 | DTC Client socket (2) | Closed.
2026-02-02 17:26:28.202 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:26:28.202 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:26:28.202 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:26:28.218 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:26:28.218 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:26:28.218 | DTC - Sub Instance | Disconnected.
2026-02-02 17:26:28.218 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:26:28.218 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-02-02 17:26:30.218 |
2026-02-02 17:26:30.218 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:26:30.218 | DTC Client socket (2) | Creating socket.
2026-02-02 17:26:30.218 | DTC Client socket (2) | New receive buffer size: 0
2026-02-02 17:26:30.218 | DTC Client socket (2) | Connecting to IP: 127.0.0.1.
2026-02-02 17:26:30.219 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:26:30.219 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:26:30.219 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:26:38.159 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:26:38.159 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-02-02 17:26:38.159 | DTC Client socket (3) | Closed.
2026-02-02 17:26:50.216 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:26:50.216 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:26:50.216 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:26:50.232 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:26:50.232 | DTC Client socket (2) | CloseSocket call.
2026-02-02 17:26:50.233 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-02-02 17:26:50.233 | DTC - Sub Instance | Disconnected.
2026-02-02 17:26:50.233 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:26:52.242 |
2026-02-02 17:26:52.242 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:26:52.242 | DTC Client socket (3) | Creating socket.
2026-02-02 17:26:52.242 | DTC Client socket (3) | New receive buffer size: 0
2026-02-02 17:26:52.242 | DTC Client socket (3) | Connecting to IP: 127.0.0.1.
2026-02-02 17:26:52.243 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:26:52.243 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:26:52.244 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:27:00.173 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:27:00.173 | DTC Client socket (4) | Socket gracefully closed by remote side.
2026-02-02 17:27:00.173 | DTC Client socket (4) | Closed.
2026-02-02 17:27:12.238 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:27:12.238 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:27:12.238 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:27:12.253 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:27:12.254 | DTC Client socket (3) | CloseSocket call.
2026-02-02 17:27:12.254 | DTC - Sub Instance | Disconnected.
2026-02-02 17:27:12.254 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:27:12.254 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2026-02-02 17:27:14.252 |
2026-02-02 17:27:14.253 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:27:14.253 | DTC Client socket (4) | Creating socket.
2026-02-02 17:27:14.253 | DTC Client socket (4) | New receive buffer size: 0
2026-02-02 17:27:14.253 | DTC Client socket (4) | Connecting to IP: 127.0.0.1.
2026-02-02 17:27:14.254 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:27:14.254 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:27:14.254 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:27:22.189 | DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:27:22.189 | DTC Client socket (5) | Socket gracefully closed by remote side.
2026-02-02 17:27:22.189 | DTC Client socket (5) | Closed.
2026-02-02 17:27:34.245 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:27:34.245 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:27:34.245 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:27:34.261 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:27:34.261 | DTC Client socket (4) | CloseSocket call.
2026-02-02 17:27:34.261 | DTC - Sub Instance | Disconnected.
2026-02-02 17:27:34.261 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:27:34.261 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2026-02-02 17:27:36.274 |
2026-02-02 17:27:36.275 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:27:36.275 | DTC Client socket (5) | Creating socket.
2026-02-02 17:27:36.275 | DTC Client socket (5) | New receive buffer size: 0
2026-02-02 17:27:36.275 | DTC Client socket (5) | Connecting to IP: 127.0.0.1.
2026-02-02 17:27:36.276 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:27:36.276 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:27:36.276 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:27:44.195 | DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:27:44.195 | DTC Client socket (6) | Socket gracefully closed by remote side.
2026-02-02 17:27:44.195 | DTC Client socket (6) | Closed.
2026-02-02 17:27:56.284 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:27:56.284 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:27:56.284 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:27:56.301 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:27:56.301 | DTC Client socket (5) | CloseSocket call.
2026-02-02 17:27:56.301 | DTC - Sub Instance | Disconnected.
2026-02-02 17:27:56.301 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:27:56.301 | DTC Client socket (5) | Shutdown started. Waiting for graceful close.
2026-02-02 17:27:58.290 |
2026-02-02 17:27:58.291 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:27:58.291 | DTC Client socket (6) | Creating socket.
2026-02-02 17:27:58.291 | DTC Client socket (6) | New receive buffer size: 0
2026-02-02 17:27:58.291 | DTC Client socket (6) | Connecting to IP: 127.0.0.1.
2026-02-02 17:27:58.292 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:27:58.292 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:27:58.292 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:28:06.213 | DTC Client socket (7) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:28:06.214 | DTC Client socket (7) | Socket gracefully closed by remote side.
2026-02-02 17:28:06.214 | DTC Client socket (7) | Closed.
2026-02-02 17:28:18.291 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:28:18.291 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:28:18.291 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:28:18.307 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:28:18.307 | DTC Client socket (6) | CloseSocket call.
2026-02-02 17:28:18.307 | DTC - Sub Instance | Disconnected.
2026-02-02 17:28:18.307 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:28:18.307 | DTC Client socket (6) | Shutdown started. Waiting for graceful close.
2026-02-02 17:28:20.308 |
2026-02-02 17:28:20.308 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:28:20.308 | DTC Client socket (7) | Creating socket.
2026-02-02 17:28:20.308 | DTC Client socket (7) | New receive buffer size: 0
2026-02-02 17:28:20.308 | DTC Client socket (7) | Connecting to IP: 127.0.0.1.
2026-02-02 17:28:20.309 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:28:20.309 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:28:20.309 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:28:28.220 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:28:28.220 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-02-02 17:28:28.220 | DTC Client socket (1) | Closed.
2026-02-02 17:28:40.329 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:28:40.329 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:28:40.329 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:28:40.345 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:28:40.345 | DTC Client socket (7) | CloseSocket call.
2026-02-02 17:28:40.346 | DTC Client socket (7) | Shutdown started. Waiting for graceful close.
2026-02-02 17:28:40.346 | DTC - Sub Instance | Disconnected.
2026-02-02 17:28:40.346 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:28:42.339 |
2026-02-02 17:28:42.339 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:28:42.340 | DTC Client socket (1) | Creating socket.
2026-02-02 17:28:42.340 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:28:42.340 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:28:42.341 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:28:42.341 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:28:42.341 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:28:50.244 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:28:50.244 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-02-02 17:28:50.244 | DTC Client socket (2) | Closed.
2026-02-02 17:29:02.342 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:29:02.342 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:29:02.342 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:29:02.358 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:29:02.358 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:29:02.358 | DTC - Sub Instance | Disconnected.
2026-02-02 17:29:02.358 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:29:02.358 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-02-02 17:29:04.358 |
2026-02-02 17:29:04.358 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:29:04.358 | DTC Client socket (2) | Creating socket.
2026-02-02 17:29:04.358 | DTC Client socket (2) | New receive buffer size: 0
2026-02-02 17:29:04.358 | DTC Client socket (2) | Connecting to IP: 127.0.0.1.
2026-02-02 17:29:04.359 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:29:04.359 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:29:04.359 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:29:12.259 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:29:12.259 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-02-02 17:29:12.259 | DTC Client socket (3) | Closed.
2026-02-02 17:29:24.373 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:29:24.373 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:29:24.373 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:29:24.390 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:29:24.390 | DTC Client socket (2) | CloseSocket call.
2026-02-02 17:29:24.390 | DTC - Sub Instance | Disconnected.
2026-02-02 17:29:24.390 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:29:24.390 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2026-02-02 17:29:26.415 |
2026-02-02 17:29:26.415 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:29:26.415 | DTC Client socket (3) | Creating socket.
2026-02-02 17:29:26.415 | DTC Client socket (3) | New receive buffer size: 0
2026-02-02 17:29:26.415 | DTC Client socket (3) | Connecting to IP: 127.0.0.1.
2026-02-02 17:29:26.416 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:29:26.416 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:29:26.416 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:29:34.268 | DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:29:34.268 | DTC Client socket (4) | Socket gracefully closed by remote side.
2026-02-02 17:29:34.268 | DTC Client socket (4) | Closed.
2026-02-02 17:29:46.416 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:29:46.416 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:29:46.416 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:29:46.431 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:29:46.432 | DTC Client socket (3) | CloseSocket call.
2026-02-02 17:29:46.432 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2026-02-02 17:29:46.432 | DTC - Sub Instance | Disconnected.
2026-02-02 17:29:46.432 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:29:48.437 |
2026-02-02 17:29:48.437 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:29:48.437 | DTC Client socket (4) | Creating socket.
2026-02-02 17:29:48.437 | DTC Client socket (4) | New receive buffer size: 0
2026-02-02 17:29:48.437 | DTC Client socket (4) | Connecting to IP: 127.0.0.1.
2026-02-02 17:29:48.438 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:29:48.438 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:29:48.438 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:29:56.307 | DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:29:56.307 | DTC Client socket (5) | Socket gracefully closed by remote side.
2026-02-02 17:29:56.307 | DTC Client socket (5) | Closed.
2026-02-02 17:30:08.435 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:30:08.435 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:30:08.435 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:30:08.452 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:30:08.452 | DTC Client socket (4) | CloseSocket call.
2026-02-02 17:30:08.452 | DTC - Sub Instance | Disconnected.
2026-02-02 17:30:08.452 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:30:08.452 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2026-02-02 17:30:10.469 |
2026-02-02 17:30:10.470 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:30:10.470 | DTC Client socket (5) | Creating socket.
2026-02-02 17:30:10.470 | DTC Client socket (5) | New receive buffer size: 0
2026-02-02 17:30:10.470 | DTC Client socket (5) | Connecting to IP: 127.0.0.1.
2026-02-02 17:30:10.471 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:30:10.471 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:30:10.471 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:30:18.318 | DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:30:18.318 | DTC Client socket (6) | Socket gracefully closed by remote side.
2026-02-02 17:30:18.318 | DTC Client socket (6) | Closed.
2026-02-02 17:30:30.478 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:30:30.478 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:30:30.478 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:30:30.494 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:30:30.494 | DTC Client socket (5) | CloseSocket call.
2026-02-02 17:30:30.494 | DTC - Sub Instance | Disconnected.
2026-02-02 17:30:30.494 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:30:30.494 | DTC Client socket (5) | Shutdown started. Waiting for graceful close.
2026-02-02 17:30:32.507 |
2026-02-02 17:30:32.507 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:30:32.507 | DTC Client socket (6) | Creating socket.
2026-02-02 17:30:32.507 | DTC Client socket (6) | New receive buffer size: 0
2026-02-02 17:30:32.507 | DTC Client socket (6) | Connecting to IP: 127.0.0.1.
2026-02-02 17:30:32.508 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:30:32.508 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:30:32.508 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:30:40.359 | DTC Client socket (7) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:30:40.359 | DTC Client socket (7) | Socket gracefully closed by remote side.
2026-02-02 17:30:40.359 | DTC Client socket (7) | Closed.
2026-02-02 17:30:52.503 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:30:52.503 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:30:52.503 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:30:52.519 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:30:52.519 | DTC Client socket (6) | CloseSocket call.
2026-02-02 17:30:52.519 | DTC - Sub Instance | Disconnected.
2026-02-02 17:30:52.520 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:30:52.520 | DTC Client socket (6) | Shutdown started. Waiting for graceful close.
2026-02-02 17:30:54.518 |
2026-02-02 17:30:54.518 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:30:54.518 | DTC Client socket (7) | Creating socket.
2026-02-02 17:30:54.519 | DTC Client socket (7) | New receive buffer size: 0
2026-02-02 17:30:54.519 | DTC Client socket (7) | Connecting to IP: 127.0.0.1.
2026-02-02 17:30:54.520 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:30:54.520 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:30:54.520 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:31:02.374 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:31:02.374 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-02-02 17:31:02.374 | DTC Client socket (1) | Closed.
2026-02-02 17:31:14.510 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:31:14.510 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:31:14.510 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:31:14.526 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:31:14.526 | DTC Client socket (7) | CloseSocket call.
2026-02-02 17:31:14.526 | DTC - Sub Instance | Disconnected.
2026-02-02 17:31:14.526 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:31:14.527 | DTC Client socket (7) | Shutdown started. Waiting for graceful close.
2026-02-02 17:31:16.538 |
2026-02-02 17:31:16.538 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:31:16.539 | DTC Client socket (1) | Creating socket.
2026-02-02 17:31:16.539 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:31:16.539 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:31:16.540 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:31:16.540 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:31:16.540 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:31:24.391 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:31:24.391 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-02-02 17:31:24.391 | DTC Client socket (2) | Closed.
2026-02-02 17:31:36.527 | DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. *
2026-02-02 17:31:36.527 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:31:36.527 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:31:36.542 | DTC - Sub Instance | Waiting for socket receive thread to end
2026-02-02 17:31:36.543 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:31:36.543 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2026-02-02 17:31:36.543 | DTC - Sub Instance | Disconnected.
2026-02-02 17:31:36.543 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:31:38.542 |
2026-02-02 17:31:38.542 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:31:38.543 | DTC Client socket (2) | Creating socket.
2026-02-02 17:31:38.543 | DTC Client socket (2) | New receive buffer size: 0
2026-02-02 17:31:38.543 | DTC Client socket (2) | Connecting to IP: 127.0.0.1.
2026-02-02 17:31:38.544 | DTC - Sub Instance | Network connection to server complete.
2026-02-02 17:31:38.544 | DTC - Sub Instance | Starting socket receive thread.
2026-02-02 17:31:38.544 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none
2026-02-02 17:31:46.443 | DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:31:46.443 | DTC Client socket (3) | Socket gracefully closed by remote side.
2026-02-02 17:31:46.443 | DTC Client socket (3) | Closed.
2026-02-02 17:31:54.844 | DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:31:54.844 | DTC Client socket (2) | Socket gracefully closed by remote side.
2026-02-02 17:31:54.844 | DTC Client socket (2) | CloseSocket call.
2026-02-02 17:31:54.844 | DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 0
2026-02-02 17:31:54.845 | DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:31:54.845 | DTC Client socket (5) | Socket gracefully closed by remote side.
2026-02-02 17:31:54.845 | DTC Client socket (5) | Closed.
2026-02-02 17:31:54.846 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:31:54.846 | DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. *
2026-02-02 17:31:54.847 | DTC Client socket (6) | Socket gracefully closed by remote side.
2026-02-02 17:31:54.847 | DTC Client socket (6) | Closed.
2026-02-02 17:31:54.847 | DTC Client socket (1) | Socket gracefully closed by remote side.
2026-02-02 17:31:54.848 | DTC Client socket (1) | Closed.
2026-02-02 17:31:54.848 | DTC Client socket (7) | Socket gracefully closed by remote side.
2026-02-02 17:31:54.848 | DTC Client socket (7) | Closed.
2026-02-02 17:31:54.849 | DTC Client socket (4) | Socket gracefully closed by remote side.
2026-02-02 17:31:54.849 | DTC Client socket (4) | Closed.
2026-02-02 17:31:54.850 | DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now.
2026-02-02 17:31:54.850 | DTC Client socket (2) | Closed.
2026-02-02 17:31:54.850 | DTC - Sub Instance | Failed connections: 1
2026-02-02 17:31:54.850 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:31:54.850 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:31:54.871 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:31:54.871 | DTC - Sub Instance | Disconnected.
2026-02-02 17:31:54.871 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:31:56.873 |
2026-02-02 17:31:56.873 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:31:56.873 | DTC Client socket (1) | Creating socket.
2026-02-02 17:31:56.873 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:31:56.873 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:31:58.897 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:31:58.897 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:31:58.897 | DTC - Sub Instance | Failed connections: 2
2026-02-02 17:31:58.897 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:31:58.897 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:31:58.897 | DTC Client socket (1) | Closed.
2026-02-02 17:31:58.913 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:31:58.913 | DTC - Sub Instance | Disconnected.
2026-02-02 17:31:58.913 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:00.919 |
2026-02-02 17:32:00.919 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:00.919 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:00.919 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:00.919 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:02.947 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:02.947 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:02.947 | DTC - Sub Instance | Failed connections: 3
2026-02-02 17:32:02.947 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:02.947 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:02.948 | DTC Client socket (1) | Closed.
2026-02-02 17:32:02.964 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:02.964 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:02.964 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:04.972 |
2026-02-02 17:32:04.972 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:04.972 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:04.972 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:04.972 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:07.005 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:07.005 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:07.005 | DTC - Sub Instance | Failed connections: 4
2026-02-02 17:32:07.005 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:07.005 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:07.005 | DTC Client socket (1) | Closed.
2026-02-02 17:32:07.022 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:07.022 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:07.022 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:09.039 |
2026-02-02 17:32:09.040 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:09.040 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:09.040 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:09.040 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:11.054 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:11.054 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:11.054 | DTC - Sub Instance | Failed connections: 5
2026-02-02 17:32:11.054 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:11.054 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:11.054 | DTC Client socket (1) | Closed.
2026-02-02 17:32:11.070 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:11.070 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:11.070 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:13.059 |
2026-02-02 17:32:13.059 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:13.059 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:13.059 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:13.059 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:15.084 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:15.084 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:15.084 | DTC - Sub Instance | Failed connections: 6
2026-02-02 17:32:15.084 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:15.084 | DTC Client socket (1) | Closed.
2026-02-02 17:32:15.084 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:15.101 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:15.101 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:15.101 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:17.100 |
2026-02-02 17:32:17.101 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:17.101 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:17.101 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:17.101 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:19.127 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:19.127 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:19.127 | DTC Client socket (1) | Closed.
2026-02-02 17:32:19.127 | DTC - Sub Instance | Failed connections: 7
2026-02-02 17:32:19.127 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:19.127 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:19.143 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:19.143 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:19.143 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:21.146 |
2026-02-02 17:32:21.146 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:21.146 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:21.146 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:21.146 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:23.165 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:23.165 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:23.165 | DTC - Sub Instance | Failed connections: 8
2026-02-02 17:32:23.165 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:23.165 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:23.165 | DTC Client socket (1) | Closed.
2026-02-02 17:32:23.181 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:23.181 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:23.181 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:25.196 |
2026-02-02 17:32:25.196 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:25.197 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:25.197 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:25.197 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:27.234 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:27.235 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:27.235 | DTC - Sub Instance | Failed connections: 9
2026-02-02 17:32:27.235 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:27.235 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:27.235 | DTC Client socket (1) | Closed.
2026-02-02 17:32:27.251 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:27.251 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:27.251 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:29.259 |
2026-02-02 17:32:29.259 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:29.260 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:29.260 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:29.260 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:31.293 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:31.293 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:31.293 | DTC - Sub Instance | Failed connections: 10
2026-02-02 17:32:31.293 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:31.293 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:31.293 | DTC Client socket (1) | Closed.
2026-02-02 17:32:31.309 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:31.309 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:31.309 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:33.325 |
2026-02-02 17:32:33.325 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:33.325 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:33.325 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:33.325 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:35.363 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:35.363 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:35.363 | DTC - Sub Instance | Failed connections: 11
2026-02-02 17:32:35.363 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:35.363 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:35.363 | DTC Client socket (1) | Closed.
2026-02-02 17:32:35.379 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:35.379 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:35.379 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:37.380 |
2026-02-02 17:32:37.381 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:37.381 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:37.381 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:37.381 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:39.413 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:39.413 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:39.413 | DTC - Sub Instance | Failed connections: 12
2026-02-02 17:32:39.413 | DTC Client socket (1) | Closed.
2026-02-02 17:32:39.413 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:39.413 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:39.436 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:39.437 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:39.437 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:41.445 |
2026-02-02 17:32:41.445 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:41.445 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:41.445 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:41.445 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:43.476 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:43.476 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:43.476 | DTC Client socket (1) | Closed.
2026-02-02 17:32:43.477 | DTC - Sub Instance | Failed connections: 13
2026-02-02 17:32:43.477 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:43.477 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:43.484 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:43.484 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:43.484 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:45.487 |
2026-02-02 17:32:45.487 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:45.487 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:45.487 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:45.487 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:47.509 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:47.509 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:47.509 | DTC - Sub Instance | Failed connections: 14
2026-02-02 17:32:47.509 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:47.509 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:47.509 | DTC Client socket (1) | Closed.
2026-02-02 17:32:47.525 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:47.525 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:47.525 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:49.531 |
2026-02-02 17:32:49.532 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:49.532 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:49.532 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:49.532 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:51.562 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:51.562 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:51.562 | DTC Client socket (1) | Closed.
2026-02-02 17:32:51.562 | DTC - Sub Instance | Failed connections: 15
2026-02-02 17:32:51.562 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:51.562 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:51.574 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:51.574 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:51.574 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:53.581 |
2026-02-02 17:32:53.581 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:53.581 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:53.581 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:53.581 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:55.595 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:55.595 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:55.595 | DTC - Sub Instance | Failed connections: 16
2026-02-02 17:32:55.595 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:55.595 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:55.595 | DTC Client socket (1) | Closed.
2026-02-02 17:32:55.605 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:55.605 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:55.605 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:57.603 |
2026-02-02 17:32:57.603 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:32:57.603 | DTC Client socket (1) | Creating socket.
2026-02-02 17:32:57.603 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:32:57.603 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:32:59.628 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:32:59.628 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:32:59.628 | DTC - Sub Instance | Failed connections: 17
2026-02-02 17:32:59.628 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:32:59.628 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:32:59.629 | DTC Client socket (1) | Closed.
2026-02-02 17:32:59.644 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:32:59.644 | DTC - Sub Instance | Disconnected.
2026-02-02 17:32:59.644 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:33:01.644 |
2026-02-02 17:33:01.644 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:33:01.645 | DTC Client socket (1) | Creating socket.
2026-02-02 17:33:01.645 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:33:01.645 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:33:03.669 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:33:03.669 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:33:03.669 | DTC - Sub Instance | Failed connections: 18
2026-02-02 17:33:03.669 | DTC Client socket (1) | Closed.
2026-02-02 17:33:03.669 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:33:03.669 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:33:03.684 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:33:03.684 | DTC - Sub Instance | Disconnected.
2026-02-02 17:33:03.684 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:33:05.700 |
2026-02-02 17:33:05.700 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:33:05.700 | DTC Client socket (1) | Creating socket.
2026-02-02 17:33:05.700 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:33:05.700 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:33:07.717 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:33:07.717 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:33:07.717 | DTC - Sub Instance | Failed connections: 19
2026-02-02 17:33:07.717 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:33:07.717 | DTC Client socket (1) | Closed.
2026-02-02 17:33:07.717 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:33:07.732 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:33:07.732 | DTC - Sub Instance | Disconnected.
2026-02-02 17:33:07.732 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:33:09.732 |
2026-02-02 17:33:09.732 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:33:09.732 | DTC Client socket (1) | Creating socket.
2026-02-02 17:33:09.732 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:33:09.732 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:33:11.758 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:33:11.758 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:33:11.758 | DTC - Sub Instance | Failed connections: 20
2026-02-02 17:33:11.758 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:33:11.758 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:33:11.758 | DTC Client socket (1) | Closed.
2026-02-02 17:33:11.774 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:33:11.775 | DTC - Sub Instance | Disconnected.
2026-02-02 17:33:11.775 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:33:13.780 |
2026-02-02 17:33:13.780 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:33:13.780 | DTC Client socket (1) | Creating socket.
2026-02-02 17:33:13.780 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:33:13.780 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:33:15.799 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:33:15.799 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:33:15.799 | DTC - Sub Instance | Failed connections: 21
2026-02-02 17:33:15.799 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:33:15.799 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:33:15.799 | DTC Client socket (1) | Closed.
2026-02-02 17:33:15.815 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:33:15.815 | DTC - Sub Instance | Disconnected.
2026-02-02 17:33:15.815 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:35:15.813 |
2026-02-02 17:35:15.813 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:35:15.813 | DTC Client socket (1) | Creating socket.
2026-02-02 17:35:15.813 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:35:15.813 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:35:17.846 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:35:17.846 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:35:17.846 | DTC Client socket (1) | Closed.
2026-02-02 17:35:17.847 | DTC - Sub Instance | Failed connections: 22
2026-02-02 17:35:17.847 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:35:17.847 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:35:17.863 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:35:17.863 | DTC - Sub Instance | Disconnected.
2026-02-02 17:35:17.863 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:37:17.864 |
2026-02-02 17:37:17.864 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:37:17.864 | DTC Client socket (1) | Creating socket.
2026-02-02 17:37:17.864 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:37:17.864 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:37:19.897 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:37:19.897 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:37:19.897 | DTC Client socket (1) | Closed.
2026-02-02 17:37:19.897 | DTC - Sub Instance | Failed connections: 23
2026-02-02 17:37:19.897 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:37:19.897 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:37:19.913 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:37:19.913 | DTC - Sub Instance | Disconnected.
2026-02-02 17:37:19.913 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:38:55.194 | Sierra Chart account data changed. Requesting updated account information.
2026-02-02 17:38:56.296 | Successfully processed Sierra Chart account data.
2026-02-02 17:38:56.296 | Requested user files to download.
2026-02-02 17:39:19.917 |
2026-02-02 17:39:19.917 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:39:19.917 | DTC Client socket (1) | Creating socket.
2026-02-02 17:39:19.917 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:39:19.917 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:39:21.950 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:39:21.950 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:39:21.950 | DTC - Sub Instance | Failed connections: 24
2026-02-02 17:39:21.950 | DTC Client socket (1) | Closed.
2026-02-02 17:39:21.950 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:39:21.950 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:39:21.966 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:39:21.966 | DTC - Sub Instance | Disconnected.
2026-02-02 17:39:21.966 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:41:21.982 |
2026-02-02 17:41:21.982 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:41:21.983 | DTC Client socket (1) | Creating socket.
2026-02-02 17:41:21.983 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:41:21.983 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:41:23.997 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:41:23.997 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:41:23.997 | DTC - Sub Instance | Failed connections: 25
2026-02-02 17:41:23.997 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:41:23.997 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:41:23.997 | DTC Client socket (1) | Closed.
2026-02-02 17:41:24.018 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:41:24.018 | DTC - Sub Instance | Disconnected.
2026-02-02 17:41:24.018 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:43:24.021 |
2026-02-02 17:43:24.021 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:43:24.021 | DTC Client socket (1) | Creating socket.
2026-02-02 17:43:24.021 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:43:24.021 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:43:26.053 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:43:26.053 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:43:26.054 | DTC - Sub Instance | Failed connections: 26
2026-02-02 17:43:26.054 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:43:26.054 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:43:26.054 | DTC Client socket (1) | Closed.
2026-02-02 17:43:26.070 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:43:26.070 | DTC - Sub Instance | Disconnected.
2026-02-02 17:43:26.070 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:45:26.071 |
2026-02-02 17:45:26.071 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:45:26.072 | DTC Client socket (1) | Creating socket.
2026-02-02 17:45:26.072 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:45:26.072 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:45:28.103 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:45:28.103 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:45:28.103 | DTC - Sub Instance | Failed connections: 27
2026-02-02 17:45:28.103 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:45:28.103 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:45:28.103 | DTC Client socket (1) | Closed.
2026-02-02 17:45:28.119 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:45:28.119 | DTC - Sub Instance | Disconnected.
2026-02-02 17:45:28.119 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:47:28.132 |
2026-02-02 17:47:28.132 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:47:28.132 | DTC Client socket (1) | Creating socket.
2026-02-02 17:47:28.132 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:47:28.132 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:47:30.156 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:47:30.156 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:47:30.156 | DTC - Sub Instance | Failed connections: 28
2026-02-02 17:47:30.156 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:47:30.156 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:47:30.156 | DTC Client socket (1) | Closed.
2026-02-02 17:47:30.173 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:47:30.173 | DTC - Sub Instance | Disconnected.
2026-02-02 17:47:30.173 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:49:30.171 |
2026-02-02 17:49:30.172 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099
2026-02-02 17:49:30.172 | DTC Client socket (1) | Creating socket.
2026-02-02 17:49:30.172 | DTC Client socket (1) | New receive buffer size: 0
2026-02-02 17:49:30.172 | DTC Client socket (1) | Connecting to IP: 127.0.0.1.
2026-02-02 17:49:32.201 | DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. *
2026-02-02 17:49:32.201 | DTC Client socket (1) | CloseSocket call.
2026-02-02 17:49:32.201 | DTC Client socket (1) | Closed.
2026-02-02 17:49:32.201 | DTC - Sub Instance | Failed connections: 29
2026-02-02 17:49:32.201 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2026-02-02 17:49:32.201 | Select 'File >> Disconnect' to prevent further connection attempts.
2026-02-02 17:49:32.217 | DTC Client socket (0) | CloseSocket call.
2026-02-02 17:49:32.217 | DTC - Sub Instance | Disconnected.
2026-02-02 17:49:32.217 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts.
le. I am also getting this message
[2026-02-03 15:13:49]
John - SC Support - Posts: 48555
That log is from a Sub-Instance. From what it shows, there is no main instance running for that sub-instance to connect to.
How did you start that Sub-Instance?
Also, if you are having an issue with data, then you first need to ensure that the main instance is working properly. If there is a problem in the Main Instance, then that needs to be dealt with first.
