Date/Time: Wed, 25 Nov 2026 22:50:08 +0000
Reg :- Number Bars Chart Not Displaying Properly
View Count: 438
| [2026-02-02 22:47:58] |
| User286997 - Posts: 1 |
Dear Sierra Chart Support Team, I am facing an issue with the Number Bars chart not displaying properly. The numbers are not clear and appear very small, making it difficult to read the data correctly. I am using a 24-inch monitor, but even after adjusting the chart settings, the Number Bars are still not viewing properly. Kindly guide me on the correct settings or let me know how to fix this issue. Please let me know if you need any screenshots or additional details from my side. Thank you for your support. Regards, Date Time Of Last Edit: 2026-02-02 22:48:09
| [2026-02-02 22:48:31] |
Refer to the following: Numbers Bars: Scaling a Numbers Bars Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
