Date/Time: Wed, 25 Nov 2026 23:00:20 +0000
Everything Set Up Correctly?
View Count: 554
[2026-02-02 10:50:10]
User847571 - Posts: 5
I want to be sure I have all set up correctly to start trading with the Denali Feed and service package 11. Do I need to pay for something else? I am signing up now with GFF Broker and clearing with Dorman and should be approved today or tomorrow
[2026-02-02 17:46:08]
What order routing service will you be using with GFF brokers?
[2026-02-03 13:02:56]
I will use Teton routing service and Denali exchange for data
[2026-02-03 15:55:43]
Sierra_Chart Engineering - Posts: 25484
You still have to activate the exchanges that you need real-time data for. What symbols will you be trading?
Date Time Of Last Edit: 2026-02-03 15:55:55
[2026-02-03 16:10:09]
emini sp only
[2026-02-03 16:35:29]
You need to go through the setup for the data for the CME Group by following the instructions at the following link:
You will want to activate one of the following exchanges depending on whether you need Market Depth data or not:
- CME Non-Professional Top-of-Book
- CME with Market
Also, once GFF tells you that they have finished the setup for your account with the Teton Order Routing Service, you will need to finish the setup by following the instructions at the following link starting at Step #6:
Sierra Chart Teton Futures Order Routing: Setup Instructions
[2026-02-11 13:15:31]
I have decided to go with AMP futures. I want to confirm you still work with them as I notice on the Broker page their link is not hilited like the rest.
Once I fund the account with them what do i need to tell them that i will connect with Teton?
[2026-02-11 13:59:55]
Yes AMP is supported and you can find the setup instructions here for Teton:
Yes.
Date Time Of Last Edit: 2026-02-11 14:01:08
