Date/Time: Wed, 25 Nov 2026 22:42:15 +0000
trade service log
View Count: 472
| [2026-01-30 20:22:02] |
| Marzel - Posts: 2 |
Hello, how can I get the trade service log to stop popping up when Im in a trade?
| [2026-01-30 21:54:54] |
If the Trade Service Log is popping open, then there is something important that has been written to the log that the system is wanting you to be aware of. You should check to see what it states and take measures to avoid whatever it is. If you want to post your log for us to take a look, then please get us the log by following these instructions: Support Board Posting Information: Providing Lines From Trade Service Log There is the following setting, that will prevent the Message Log and the Trade Service Log from opening, regardless of what is written to it. But we do not recommend it, as the reason these are opening is there is something important. General Settings Window: Never Automatically Open Message Log or Trade Service Log (Global Settings >> General Settings >> Log >> Log) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
