Date/Time: Tue, 17 Nov 2026 18:09:02 +0000
Prop firm wants direct confirmation regarding connection state and execution handling
View Count: 431
| [2026-01-30 00:02:04] |
| Harleking - Posts: 1 |
Hi, so I had issues with ghost Orders happening while I wasn't even there which resulted in big losses. Like 300 trades in a 4minute timeframe. The timeframe in question is the last 30minutes of the the goblex Session in the ES, 29th of January. (15:30-16 CT) I posted the trade activity log and trading statistic which showed no trades on my part occured and that the last trade was 9hours prior, but that wasn't sufficient. So I will just forward there message and hope you are able to help me out on that. Don't know how exactly this works but the account in question is "HFF-41328-7998" I checked before hand to have no Order left open (have rhitmic screenshot) and hope you can help me out and confirm the issue was not on my part. "Thank you for checking the Sierra Chart trade activity logs and for sharing the screenshots and additional details, we appreciate you taking the time to do that. Based on what you’ve provided, we understand your position clearly. The behavior you described (particularly the large number of executions appearing in a very short window while the platform was not open) is consistent with patterns we have seen in cases involving delayed order execution or order state desynchronization at the connectivity level. In these situations, trades may execute or reconcile in rapid succession once a connection is re-established, even though no manual interaction occurred at that time. That said, in order for us to formally step in and reconcile or compensate the affected activity, we need direct confirmation from Sierra Chart regarding the connection state and execution handling during that specific timeframe. While your local trade log not showing those executions is an important data point, Sierra’s internal diagnostics can confirm whether: A delayed execution or resynchronization event occurred Orders were held or released due to connectivity latency If Sierra Chart can confirm that such a discrepancy or delayed execution behavior occurred, we will be able to move forward immediately with support and corrective action on our end. Please let us know once you hear back from Sierra Chart, or feel free to forward their response directly. We’ll take it from there right away." Kind Regards Date Time Of Last Edit: 2026-01-30 00:11:27
| [2026-01-30 15:23:27] |
| John - SC Support - Posts: 48555 |
We do not have a way to check for what they are stating. That information does not exist. But, we can state that Sierra Chart does not send orders if there is not a connection, and it does not "store" those orders to be sent later. This could create a bad situation (such as what they are describing), hence we do not allow this to occur in our software. Therefore, if your Trade Activity Log is not showing any orders being sent at that time, then no orders were sent from Sierra Chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
