Date/Time: Wed, 25 Nov 2026 22:42:18 +0000
assign color for different volume value
View Count: 465
[2026-01-29 15:34:23]
User6509932 - Posts: 5
attached is table in subgraph region of footprint chart, is there any way to change the background color of box showing value of volume based on actual vol? let say
imagevol.png / V - Attached On 2026-01-29 15:34:18 UTC - Size: 9.9 KB - 233 views
[2026-01-29 16:12:00]
The only option for coloring the background based on a specific volume for the Numbers Bars Calculated Values studies is the option for "Color Background Based on Value Percentage" - which does it based on the percentage of the maximum value found. There is no support for coloring based on actual values. Refer to the following:
Numbers Bars: Color Background Based on Value Percentage
