Date/Time: Thu, 10 Sep 2026 06:50:20 +0000
[User Discussion] - Trying to use Study data in an ACSIL function
View Count: 3979
[2014-10-21 17:36:58]
NickH09 - Posts: 10
Hello! Im try to use the ADXVMA study's output data to generate the actual color (Red, Yellow and Blue) in my study and then coloring the price, but im having trouble. I see the three colors drawn(i use the color bar draw style) but they are disordered and without a patron.
I don't know if it can be disable the setting (Based On: ) that the studies have as default. Can have any impact on data?. I don't know if the problem is in the color logic or getting the data from the ADXVMA.
I'd greatly appreciate someone's help, here it is the code:
#include "sierrachart.h"
#include <string>
using namespace std;
SCDLLName("STDref")
SCSFExport scsf_STDref(SCStudyGraphRef sc)
  SCSubgraphRef ColorBar = sc.Subgraph[1];
  if (sc.SetDefaults)
    sc.GraphName = "STDref";
    sc.StudyDescription = "STDref";
    sc.FreeDLL = 0;
    sc.AutoLoop = 1;
    sc.GraphRegion = 0;
    sc.Subgraph[0].Name = "STDref";
    sc.Subgraph[0].PrimaryColor = RED;
    sc.Subgraph[0].DrawStyle = DRAWSTYLE_COLORBAR;
    sc.Subgraph[0].LineWidth = 2;
    sc.CalculationPrecedence = LOW_PREC_LEVEL;
    sc.Input[0].Name = "Study Reference 1";
    sc.Input[0].SetStudyID(1);
    return;
  SCFloatArray StudyReference1;
  sc.GetStudyArrayUsingID(sc.Input[0].GetStudyID(), 4, StudyReference1); // It's the same to point to ADXVMA sg.Subgraph[0] or ma sg.Subgraph[4] ?
  int ValueStudy1 = StudyReference1[sc.Index];
  int ValueStudy1b = StudyReference1[sc.Index - 1];
  int ColorSt1 = WHITE;
  if (ValueStudy1 > ValueStudy1b) {
    ColorSt1 = BLUE;
  else if (ValueStudy1 < ValueStudy1b) {
    ColorSt1 = RED;
  else if (ValueStudy1 == ValueStudy1b) {
    ColorSt1 = YELLOW;
  sc.Subgraph[0][sc.Index] = sc.BaseData[SC_LAST][sc.Index];
  sc.Subgraph[0].DataColor[sc.Index] = ColorSt1;
[2014-10-21 18:04:48]
eRamone - Posts: 1
You need to change data type of variables ValueStudy to float
float ValueStudy1 = StudyReference1[sc.Index];
float ValueStudy1b = StudyReference1[sc.Index - 1];
Regards
