Date/Time: Tue, 10 Nov 2026 17:33:07 +0000
ndx??
View Count: 624
| [2026-01-24 14:54:37] |
| User849502 - Posts: 485 |
Hi John, I googled how to get NDX index on SC, and it said it was covered by Danali and the symbol is NDX-NQGI. But when I type it in I get symbol settings not found for the current service. Can you help? thank you Karen |
| [2026-01-26 16:39:04] |
| John - SC Support - Posts: 48483 |
We do not have data for the NDX itself. We do have data for the NDX VIX (CBOE NASDAQ-100 NDX, NDXP VIX Index) from the CBOE, but this is a Volatility Index. If this is something you would be interested in, then you have to pay for the "CBOE Indices" exchange to get the data (they do not allow for delayed streaming data for that data). Follow the instructions at the following link to get that data: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* It looks like you have a connection to DTN IQ Feed, in which case you should check with them if they have the Nasdaq Index. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-26 17:22:45] |
genius, duh I forgot that. thanks mate
