Date/Time: Wed, 25 Nov 2026 22:26:04 +0000
custom text drawing presets?
View Count: 485
| [2026-01-20 17:47:38] |
| User981449 - Posts: 52 |
Hi, I’d like to create a few custom text‑drawing buttons in the control bar, and I want each of them to use a different preset (different text). However, all I can see are the same CDT1, CDT2, etc. How can I set different saved presets? Thank you
| [2026-01-20 18:35:23] |
The general instructions to create different control bar buttons to select a tool and a configuration are here: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step The Text drawings have a configuration entry for "Default Text". Fill this in with the text you want and save the configuration. Then change and save the configuration as needed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
