Date/Time: Wed, 25 Nov 2026 22:26:18 +0000
No compiler found / empty compiler response after remote build
View Count: 765
[2026-01-20 16:47:14]
User105070 - Posts: 7
Hello Sierra Chart Support Team,
We are running into an issue when building studies/strategies using the Remote Build service.
The Remote Build completes successfully and reports:
“The remote build is complete.
The build succeeded.
The compiler response is empty.”
However, we also see a message indicating no compiler found, and as a result:
The study/strategy does not appear to execute as expected
There is no backtesting data or results generated
We’re trying to understand:
Why the compiler response would be empty if the build is reported as successful
Whether the “no compiler found” condition indicates a local configuration issue (e.g. Visual C++ components, permissions, or paths), even when using Remote Build
Whether this issue could directly cause strategies to load but produce no historical backtest results
Additional context:
We are relying on Remote Build, not a local compiler
The code builds without reported syntax errors
The problem is consistent across rebuilds
Could you please advise:
What conditions cause an empty compiler response?
What we should check to confirm the compiler and build environment are functioning correctly?
Whether this is a known cause of strategies not producing backtest output
Thank you for your help.
Best regards,
Lloyd
[2026-01-20 18:02:51]
These responses are normal and means everything finished correctly.
What exactly is the error you are seeing with regards to the "No Compiler Found"? If we can see an image of what you are seeing, it would help us understand better.
[2026-01-20 19:10:32]
remote standard build
-- Starting remote build of Custom Studies Source files: 19.01.26_No2_ALPHA_V20_TV_Final.cpp. 64-bit -- 14:07:40
Allow time for the server to compile the files and build the DLL.
Server: https://build.sierrachart.com
Writing file to: C:\SierraChart\Data\19.01.26_No2_ALPHA_V20_TV_Final_64.dll
-- End of Build -- 14:07:45
Build with visual C++-Release
-- Starting build of Custom Studies Source files: 19.01.26_No2_ALPHA_V20_TV_Final.cpp. -- 14:09:44
C:\WINDOWS\system32\cmd.exe /C "C:\SierraChart\ACS_Source\VisualCCompile.Bat"
C:\SierraChart\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio\18\BuildTools\VC\Auxiliary\Build\vcvarsall.bat" amd64
** Visual Studio 2026 Developer Command Prompt v18.2.0
** Copyright (c) 2025 Microsoft Corporation
[DEBUG:ext\vcvars.bat] Found potential v145 version file: 'Microsoft.VCToolsVersion.VC.14.50.18.0.txt'
[DEBUG:ext\vcvars.bat] Testing v145 version file: 'Microsoft.VCToolsVersion.VC.14.50.18.0.txt'
[vcvarsall.bat] Environment initialized for: 'x64'
C:\SierraChart\ACS_Source\19.01.26_No2_ALPHA_V20_TV_Final.cpp(113): warning C4244: 'initializing': conversion from 'double' to 'int', possible loss of data
Creating library 19.01.26_No2_ALPHA_V20_TV_Final.lib and object 19.01.26_No2_ALPHA_V20_TV_Final.exp
Generating code
Finished generating code
-- End of Build -- 14:09:50
[2026-01-20 21:41:34]
We do not see any issues in the information you supplied. We are wondering why you are building remotely and then building locally, but in both cases everything worked fine. You just have the following item showing from the local build:
You should look into this, but it is only a warning and does not stop the compilation.
