Date/Time: Wed, 25 Nov 2026 22:26:24 +0000
Forex CFD symbols for Interactive Brokers
View Count: 471
| [2026-01-19 11:11:58] |
| User44804 - Posts: 9 |
I encountered the following problem: IB has different Symbols for Forex-Cash and Forex-CFDs. For currency trading the CFDs are used whereas Forex Cash is only used for currency conversions. However, in Sierra Chart i could only find the Forex-Cash Symbols for IB. These symbols are not suitable for trading. What's the correct format for the IB Forex-CFDs and could you provide them in Sierra Chart instead of the useless Cash symbols?
| [2026-01-20 07:04:59] |
| Sierra_Chart Engineering - Posts: 25484 |
You should be able to determine the correct format by referring to this page: Interactive Brokers Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-20 10:24:52] |
After some experimenting i found the solution: For EUR/USD the Format is: EUR-CFD-SMART-USD-BAAVG |
