Date/Time: Wed, 25 Nov 2026 22:26:21 +0000
TPO Fractional display off
View Count: 491
| [2026-01-14 20:59:26] |
| pavel.lysenka - Posts: 50 |
How can i turn off this fractional view off on my TPO chart?
| Attachment Deleted. |
| [2026-01-14 22:27:24] |
That is based on the Price Scale. You must have the Price Scale set to display in fractional values. Refer to the following: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-15 21:11:59] |
I dont see a option to change fractional value.
| [2026-01-15 21:43:47] |
The setting for "Price Display Format" is what drives this. In your image, this is showing as 0.01, so you should not have a fractional value showing for the values on the TPO. We need to see an image of the entire chart by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-16 17:22:59] |
Hello here is the link with the image: https://www.sierrachart.com/image.php?Image=1768584134594.png |
| [2026-01-16 18:44:37] |
| Sierra_Chart Engineering - Posts: 25484 |
Change the Value Format for the TPO Profile Chart study to Inherited: Chart Studies: Settings and Inputs Tab >> Value Format And make sure the Price Display Format in the Chart Settings for the chart is set as it should: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-01-17 14:00:24] |
What should the price display format be?
| [2026-01-17 19:20:19] |
What is the symbol of the chart?
