Date/Time: Wed, 25 Nov 2026 22:26:23 +0000
numbers bars pullback column
View Count: 811
[2026-01-14 20:51:22]
coachted - Posts: 545
I am trying to get a better understanding of the numbers pullback column ...why does the column reset sometimes after 5 prices and sometimes it's bigger..
[2026-01-14 22:22:46]
Refer to the following:
Chart Settings: Historical Pullback Data (Chart >> Chart Settings >> Chart Data >> Chart Data menu)
[2026-01-15 14:15:54]
Thank you, also is the code for the Ask/Bid Volume difference bars available and if so could you provide me .cpp file it is contained in...thank you
[2026-01-15 17:12:25]
The code for the "Ask/Bid Volume Difference Bars" is in the "Studies8.cpp" file in the "ACS_Source" folder under your main Sierra Chart installation folder. Refer to the following:
How to Build an Advanced Custom Study from Source Code
[2026-01-15 18:54:23]
Hi John, last question, is it possible to get Denali feed updating my charts and execute through rithmic order routing?
[2026-01-15 19:08:48]
Yes. This is specifically how Sierra Chart is setup to work and is our recommendation. Refer to the following:
Denali Exchange Data Feed: Integration with Trading Services
[2026-01-15 20:35:58]
ok so can i use rithmic for the rounting in SC and then use the rithmic data in another platfrom as per rithmics info
[2026-01-15 21:34:43]
If you are logged into an account with Rithmic through Sierra Chart, then you can not access that account on another system. This is a restriction on the interface that Rithmic uses with Sierra Chart, in that it only allows for a single connection to that account.
[2026-01-16 18:45:41]
Good afternoon,
I am curious if the trade log activity has a script in any of the .cpp files?
[2026-01-19 15:23:06]
We are not understanding what you are asking. Please try wording this a little different so we know what exactly you are looking for.
[2026-01-19 15:27:30]
I am looking to find out if there is a script/code inside a studies.cpp file for the trade activity log
Date Time Of Last Edit: 2026-01-19 15:28:49
[2026-01-19 21:44:37]
To do what with the Trade Activity Log?
Also, you should look through the source code that is available to see if you can find what you are looking for. Refer to the following specifically, and the rest of the information that page:
How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies
[2026-01-20 19:18:35]
I am looking to find a list of field names that can be used to code custom studies can you provide me where i can find that.
[2026-01-20 21:43:20]
We are not understanding what you mean by "field names".
All of the ACSIL documentation can be found starting at the following link:
Table of Contents | (Advanced Custom Study/System Interface and Language (ACSIL))
[2026-01-20 22:35:08]
so for example in the trade activity log there is a tab called trade activity...if i click trade activity there are columns...suppose i want to write code that would capture transdatetime or fillprice or any other information contained in the columns...how do i reference the data in the columns... is there a place in sierra charts support material that would state the exact language i need to reference the data in each of those columns.
Or can i only access this data by manually exporting the tradelog?
Date Time Of Last Edit: 2026-01-20 22:37:51
[2026-01-21 15:09:43]
There is not a way to specifically access the fields from the Trade Activity Log with ACSIL. Rather, you are accessing the Order information or the Position information. The documentation for these are here:
Automated Trading From an Advanced Custom Study: Getting Order Information
Automated Trading From an Advanced Custom Study: Getting Trade Position Data
[2026-01-21 15:12:42]
Thank you
