Date/Time: Wed, 25 Nov 2026 22:21:08 +0000
how to increase the number of instances?
View Count: 522
[2026-01-14 16:50:28]
M77 - Posts: 1
I would like to increase the number of allowed concurrent Sierra Chart instances on my account to 3.
This is for my own multi-machine analysis and monitoring setup. How much does it cost?
Thank you.
[2026-01-14 17:27:08]
The way to do this is to change to one of the higher packages ("Integrated Advanced" (Package 11) or "Integrated Advanced with MBO" (Package 12)). The lowest cost option would be to change to the "Integrated Advanced" package which is $10.00 more per month than the package you are currently on.
Refer to the following for how to change packages:
Sierra Chart Purchase and License Information: Changing Package
Just be aware that if you want to use our Denali Exchange Data Feed, you can only get the data to two different computers at the same time. Refer to the following:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
